VPN video tutorial for Ipsec L2tp mikrotik
L2TP VPN Tutorial
https://youtu.be/vPxGIz0_Pnw
Hope this helps
Hi Zipvault,
Thanks for posting that.
One question, I’m trying to connect from iphone ios 10.2.1 and I can connect over cellular to the l2tp vpn.
However I can only access the Router Lan IP address and a host in the DMZ. I cannot connect to hosts on the LAN
Hello i half understood this
Seems you want to do a “remote user vpn”?
U may need to portforward UDP 500 or 4500 for the wan
Hi ZipVault,
Yes, I want a remote user (roadwarrior) to conenct to vpn using iphone.
Do you mean forward forward those ports from the WAN to the Local Lan or Lan to Wan?
I forward all ports to WAN from LAN at the moment so that should be the problem.
Regards
Rob
