I’m going to add a RB951G on my LAN at work and create a VPN using the pptp protocol.
What I want is to be able to access my LAN at work with my laptop when I’m roaming and use the local HP network printer wich has a fixed IP (192.168.0.254), access some SMB shares using the IP (//192.168.0.200/Data) etc.
My work subnet is 192.168.0.1/24. DHCP pool is 192.168.0.10 - 192.168.0.199
I’m going to setup my PPTP VPN using this tutorial https://wiki.mikrotik.com/wiki/Manual:Interface/PPTP and give my laptops an IP in the same subnet using addresses left out by DHCP (ex. 192.168.0.201). I use this setup for my home VPN and it works fine.
My question is what happens when for example I’m with my laptop in a place where the local subnet for internet access is also 192.168.0.1/24 wich is common? If I connect to my VPN will I be able to access the resources in my remote LAN or will there be routing issues?
My laptops will run Windows 10 and MacBook Pro connecting to VPN over WiFi. I’ll try it for a few days. Does connecting to a VPN automatically selects that connection as default gateway in Windows 10 and MacOS or do I have to manually set that up?
You can use a pool in a different subnet for the pptp clients, and use dst-nat rules to provide aliases for the devices in the company LAN, and src-nat rules to make these devices respond to the RB’s address if the RB is not their default gateway.
I’d be more afraid of problems associated to establishing a PPTP tunnel through a NAT, which must be there as you say the client PC gets an IP from 192.168.0.0/24.
On MAC it will work just check: Open Network Configurations > Click VPN interface Created > Advanced > Check Send All Traffic Over VPN Connection. I use more than 10 VPN like that for my remote clients and it works perfect!
