Hi Guys,
Well i’m a newbie to mikrotik but i do know the basic features. Recently i setup a vpn connection using fixed public IP but users complained there were latency.
I had to setup another VPN using noip. That is, if they experienced latency using VPN when connecting through the public ip,they will try to connect using the noip connection.
But the issue is that it does not work both at the same time when interfaces on mirotik to the router are enable. I have to disable one of them to make it work.
Note: both vpn setup (public&no i) work separetely but I wanted both to work at the same time. It’ll be more easy for users if they have issues. They only have to disconnect and connect the another.
Thanks to provide a help from you all.
