VPN with Cisco router
Having a few issues attempting to establish an ipsec VPN between RouterOS and a Cisco 2600XM.
VPN is running across the internet with the MT and the Cisco router both running NAT for their respective LANs.
Aside from unreliable establishment of phase 2, I can’t seem to get it to pass traffic from the MT to the Cisco.
I’ve mucked around for a few hours trying different config combinations with the firewall/nat as well as reading the manual with no joy.
NAT Settings
0   ;;; No NAT for VPN
chain=srcnat action=accept src-address=192.168.2.0/24
dst-address=10.1.1.0/24
1   ;;; Global NAT
chain=srcnat action=masquerade src-address=192.168.2.0/24
Policy
 0   src-address=192.168.2.0/24:any dst-address=10.1.1.0/24:any protocol=all
     action=encrypt level=(unknown) ipsec-protocols=esp tunnel=yes
     sa-src-address=203.x.x.x sa-dst-address=124.x.x.x
     proposal=default manual-sa=none priority=0
Peer
 0   address=124.x.x.x/32:500 auth-method=pre-shared-key
     secret="xxxxxxx" generate-policy=no exchange-mode=main
     send-initial-contact=yes nat-traversal=no proposal-check=obey
     hash-algorithm=sha1 enc-algorithm=aes-128 dh-group=modp1024 lifetime=1d
     lifebytes=0
Proposal
 0   name="default" auth-algorithms=sha1 enc-algorithms=aes-128 lifetime=1h
     pfs-group=none
Installed SA’s
 0 E  spi=0x59F9791D src-address=203.x.x.x dst-address=124.x.x.x
      auth-algorithm=sha1 enc-algorithm=aes replay=4 state=mature
      auth-key="xxx"
      enc-key="xxx" add-lifetime=48m/1h
      use-lifetime=0s/0s lifebytes=0/0
 1 E  spi=0x60ECC79 src-address=124.x.x.x dst-address=203.x.x.x
      auth-key="xxx"
      enc-key="xxx"
      addtime=oct/14/2007 19:36:11 add-lifetime=48m/1h
      usetime=oct/14/2007 19:36:14 use-lifetime=0s/0s current-bytes=21720
      lifebytes=0/0
Cisco Router
crypto isakmp policy 1
 encr aes
 authentication pre-share
 group 2
crypto isakmp key 6 xxx address 203.x.x.x
crypto ipsec transform-set VPN esp-aes esp-sha-hmac
crypto map VPN 1 ipsec-isakmp
 set peer 203.x.x.x
 set transform-set VPN
 match address VPN
ip access-list extended NAT
 deny   ip 10.1.1.0 0.0.0.255 192.168.2.0 0.0.0.255
 permit ip 10.1.1.0 0.0.0.255 any
ip access-list extended VPN
 permit ip 10.1.1.0 0.0.0.255 192.168.2.0 0.0.0.255
As shown in the Installed SA’s, traffic is passing one way but not the other. There’s a constant ping running from both sides.
I wasn’t even getting one way traffic into the MT before I added a filter rule to allow the source IP of the cisco router.
What am I missing?
