VPN WITH DDNS
Hello.
I have set a vpn server with l2tp and with a dinamic ip given by my isp, i registered the domain in changeip. When i try to set the vpn client , in connect-to i set the domain and automatically turns to numbers,user and pass, and the link works great.
But i Know when the link will down, i must to set again.
Is there a way to use the name instead of the numbers???
Try this: http://forum.mikrotik.com/t/vpn-dyndns-script/12384/7
Sam
Hello, thanks, but can you explain me what means pip.changeip.com??? or better ,what must I to set instead of pip.changeip.com???
and connect-to is this the same that server-address in L2tp-client???
regards
yes, replace that hostname with the dns name that you wish to use in l2tp-client. it will resolve that and convert to an IP when its changed.
YEAPPP, i GOT ITTTT,
THANKS A LOT
YOU’RE RESOLVED MY PROBLEM.
