VPN with multiple WAN IP
i have to WAN port (two ISP service providers), how do i configure VPN (PPTP) for connecting from home network.
with 2 ISP configure, not able to reach the WAN IP from home. with one single WAN IP it is working fine.
2 WAN(ISP) are configured for load balance and working fine.
Regards,
Hemanth S
try putting in a static route to your work VPN host to force the VPN traffic out one connection only
OR
put in a mangle/routing mark rule and coresponding static route to direct all VPN traffic out a single WAN
Hi vk7zms,
thanks for the reply.
can you explain bit more. i am not able to understand.
Regards,
Hemanth S
Thanks, i was able to resolve the issue. the mangle/ mark routing worked.
now there is other issue. i am able to connect to VPN, but after connecting i am not able to ping/access any machines in the office.
Regards,
Hemanth S
