Have configured MT 2.9 for VPN with PPTP. It works fine remotely but from certain networks (IPs). When I try to establish VPN from certain networks the request goes to MT but disconnects immediately.
MT topology is as under:
WAN 1.2.3.4
LAN 192.168.10.1
PPTP server local address 10.252.14.200
With PPTP you should be able to ping both sides. This means you should be able to ping the MT running PPTP server from the internet, and the device running the PPTP client from your Mikrotik. I have experienced the same issue with ISP’s using some form of proxy or NAT.
