Hello i am working in a company. We Have VPN.
I need to get access to my company if i am in my home
i have a routeboard 433 with a wireless antenna in my home.
they give me the ip of the vpn server for example 192.111.111.111 and a username and password
i create in the routerboard PPTP client and enter all the info.
Everything is working and PPTP satus is connected.
I can ping from the routerboard to our server in the company like 192.168.0.101(exchange server)
But if i connect my laptop to the routerboard(wireless or by lan) and ping to 192.168.0.101 it give me request timed out
i want when i connect to this routerboard by my laptop, the router should give a ip from the dhcp server in my company so i want this routerboard to be all the time connecting to my company.
Company ip range dhcp: 192.168.120 → 192.168.0.220
so can anyone one give me all the configuration.
i can resset the routerboad and follow a tutorial step by step
I don’t know if your company will be bridging their LAN to your PPTP connection. If so, you probably want to create a bridge and add the PPTP interface and your LAN interface in the same bridge.
Otherwise, you’ll probably end up adding a route for 192.168.0.0/24 across your PPTP interface. You’ll want to use a different subnet on your home LAN and masquerade traffic out your PPTP interface. You may want to hand out your office name servers via your DHCP server at home.
I suspect that adding the masquerade NAT rule will fix that.
If the office wants your home LAN bridged to the office, I suspect you will need to run an Ethernet over IP tunnel across the PPTP connection.
A lot of details depend on how your office IT run their network.
i cant put pptp client in the bridge with the lan
anyway i will give u the configuration in the company: computers ip range 192.168.0.100 - 192.168.0.254 any computer get the ip automatically from the dhcp server(192.168.0.99)
I create a pptp client and its connected… if i go tools - ping - and ping 192.168.0.99 from interface pptp i get reply
but if i ping from my computer i dont get reply
i create a bridge but i cant put pptp client in a bridge mode with ether 2
add action=masquerade chain=srcnat out-interface=YOURPPTP_INTERFACE src-address=YOUR_HOME_LAN_SUBNET
All traffic to your office from your home will appear to come from the MikroTik’s PPTP IP address.
