This is my first post so I hope that I choose the right forum ![]()
I am playing with pppoe-server, vrf and other mangles rules but I met a strange behaviour:
if I enable rp_filter (loose or strict) and I have pppoe-server bindings in vrf nothing works, neither ping;
if I disable it everything works correctly.
At this point, I think that rp_filter don’t support VRF and look only in the main table, is it right or
I did some configuration mistake?
thanks
