I start only to scratch this subject.
What I have do:
On [Router]:
# apr/18/2022 12:29:37 by RouterOS 7.2.1
# software id =
set [ find default-name=ether3 ] comment=ether3 disable-running-check=no name=ether1
set [ find default-name=ether2 ] disable-running-check=no
set [ find default-name=ether1 ] comment=ether1 disable-running-check=no name=public
/disk
set sata1 disabled=no
add name=dhcp_pool0 ranges=192.168.1.2-192.168.1.254
add name=dhcp_pool_cust_b ranges=192.168.2.2-192.168.2.254
add address-pool=dhcp_pool0 disabled=yes interface=ether1 name=dhcp1
add address-pool=dhcp_pool_cust_b disabled=yes interface=ether2 name=cust_b
/ip vrf
add interfaces=ether1 name=cust_a
add interfaces=ether2 name=cust_b
/port
set 0 name=serial0
add address=172.16.1.2/24 interface=public network=172.16.1.0
add address=192.168.2.1/24 comment=cust_b interface=ether2 network=192.168.2.0
add address=192.168.1.1/24 interface=ether1 network=192.168.1.0
/ip dhcp-client
add interface=public
add address=192.168.1.0/24 dns-server=192.168.1.1 gateway=192.168.1.1 netmask=24
add address=192.168.2.0/24 dns-server=0.0.0.0 gateway=192.168.2.1 netmask=24
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=172.16.1.254 pref-src=0.0.0.0 routing-table=main scope=30 \
suppress-hw-offload=no target-scope=10
add gateway=172.16.1.254@main routing-table=cust_a
add gateway=172.16.1.254@main routing-table=cust_b
/system identity
set name=Router
/tool romon
set enabled=yes
On ether2 I have connected, a MKT_cust_b:
ip: 192.168.2.10/24
def gw: 192.168.2.1
From MKT_cust_b I can ping/traceroute 192.168.2.1, but I can not ping/traceroute to 172.16.1.2 or to 172.16.1.254
From [Router] I can ping to 172.16.1.254 or even traceoute using vrf_custb.
So the question is, what I miss … so in the end I will be able to make traceroute from MKT_cust_b to 172.16.1.254.
Thx in advance !
