ugisduc
January 16, 2020, 10:43pm
1
What to do, if I have only one ip from provider, but need redundancy?
I found the second solution:
add address=169.254.1.2/29 interface=ether1 (169.254.1.3/29 for second router)
add address=169.254.1.1/29 interface=vrrp1
add address=50.50.50.2/30 interface=wrrp1
169.254.1.1 will be used for vrrp advertisments, 50.50.50.2 will be switched together with it. Is it right solution?
Best Regards,
Ugis
Yup, that works. But the vrrp address has to be a /32 no matter what the actual subnet size is.
-Chris
OK. But is it for any vrrp or first? I mean, 169.254.1.1? How can I assign mask /30 to 50.50.50.2?
Just for the first - the one in the same subnet you’re using for vrrp.
The other addresses can be any mask and will follow the vrrp status.
-Chris
OK! Thank’s for answer.
But anyway, it’s not clear for me, why other masks can’t be used. Because for many years I always used the same mask as for subnet and all was ok. Is there some situations, where it can make problems?
Ugis
