VRRP and preemption problem ??
I’m having problem with preemption on VRRP, i disabled preemption, but when i reboot my router, when my router come back up, it took over the master state again, no matter the priority number is the same or not.
When you turn preemption-mode=no
“a backup node will not be elected to be a master until the current master fail even if the backup node has higher priority than the current master”
http://www.mikrotik.com/testdocs/ros/2.9/ip/vrrp.php
i already did that, but still, no changes
