Not sure if this is known bug with VRRP. I am currently using Router 3.3 OS and performed the following test.
Configured CC1 (Master) and CC2 (Backup) in pre-emption mode. CC1 and CC2 both connected to a local LAN
Pulling LAN cable on CC1, CC2 changes state to Master & Running. Re-inserting cable back to CC1, CC1 becomes Master/Running and CC2 changes state to Backup. This is normal expected behaviour
In the next test, I power CC1 down and CC2 state changes to Master/Running. Powering CC1 up results in CC2 state as Backup and CC1 as Master.
Identical results to (3) obtained if both units are powered down and up simultaneously.
Only way to revert to normal behaviour in (3) and (4) is to pull one of the LAN cables. Also observed similar results in (3) & (4) in non-premption mode too
Do folk know if this is a known problem?
