VRRP config sync
Hi There
I would like to keep my backup VRRP routers config synced (firewall/mangle etc). Would it be possible to make my one Mikrotik pull configs off the other and import it on a scheduled basis?
It is possible, on first router run script that exports configuration.
On other router use fetch to get exported configuration files from first router.
so lets say a job that does /ip firewall export dumps it to a file then the other one ftp’s it? You dont perhaps have a basic example on this?
script on first rotuer
/ip firewall filter export file=firewall
script on second router
/tool fetch address=x.x.x.x src-path="firewall.rsc" mode=ftp user="admin" password="";
/import file-name=firewall.rsc
awesome thank you!
don’t forget to remove old rules before import =)
Is there a way to do this across the entire config of the router?
to do what?
