I would like to keep my backup VRRP routers config synced (firewall/mangle/hotspot/vpn etc).
Network is http://forum.mikrotik.com/t/hardware-fault-tollerance/34888/1
I want to refine idea posted in http://forum.mikrotik.com/t/vrrp-config-sync/33709/1
So i want to do two script: one running on master router (R1) to export configuration, one running on backup router (R2) to delete actually configuration and import R1 configuration.
Is there a way to export all configuration except a part (all router config except ip address/vrrp and scripts sections, these are the only two parts differents from R1 and R2)?
How to remove old configuration before import in R2?
Someone may help me writing these scripts?
Thanks in advance.
v.
