I just add the new VRRP interface to ether interface, but the VRRP interface always invalid.
I use the defaults values, and very simple config.
/interface vrrp add interface=ether2
/interface vrrp print
Flags: X - disabled, I - invalid, R - running, M - master, B - backup
NAME INTERFACE MAC-ADDRESS VRI PRI INTERVAL V V3..
0 I vrrp1 ether2 00:00:5E:00:01:01 1 100 1s 3 ipv4
/interface ethernet print
Flags: X - disabled, R - running, S - slave
NAME MTU MAC-ADDRESS ARP MASTER-PORT SWITCH
0 R ether1 1500 D4:CA:6D:3D:FF:74 enabled
1 R ether2 1500 D4:CA:6D:3D:FF:75 enabled none switch1
/system resource print
uptime: 17m19s
version: 5.24
free-memory: 52856KiB
total-memory: 62184KiB
cpu: MIPS 24Kc V7.4
cpu-count: 1
cpu-frequency: 300MHz
cpu-load: 2%
free-hdd-space: 30276KiB
total-hdd-space: 61440KiB
write-sect-since-reboot: 311
write-sect-total: 159992
bad-blocks: 0.1%
architecture-name: mipsbe
board-name: RB450
well... is it a bug ?
How to it UP ???
