What’s the norm for configuring VRRP and assigning IP addresses to interfaces.
For instance Do you just setup VRRP IP and assign to and interface and not assign a static IP to the interface itself.
Primary Eth0 – 192.168.1.2
Secondary Eth0 – 192.168.1.3
VRRP for Eth0 on both MTs – 192.168.1.1
So when I ping 192.168.1.1 or .2 I get the primary MT. I can still use .3 to get to the secondary. If the primary fails I can use .1 or .3 to get to secondary as VRRP will have taken over on the secondary.
Is it OK that I have assigned an IP to the interface itself? What is the best practice?
thanks.
