I have 2 RB450G’s using RouterOS 4.14, and I am trying to setup a VRRP interface on both routers. I’ve followed the Wiki instructions to do the following:
VIP: 192.168.1.1/32
R1: 192.168.1.254/24
R2: 192.168.253/24
R1 setup:
/interface vrrp add interface=ether1-gateway vrid=49 priority=254
/ip address add address=192.168.1.1/32 interface=vrrp1
R2 setup:
Normally R1 will be the Master, and R2 should be the Backup, however both R1 and R2 are stuck as Master (which is causing a lot a trouble).
R1:
/interface vrrp print
0 RM name="vrrp1" mtu=1500 mac-address=00:00:5E:00:01:31 arp=enabled interface=ether1-gateway vrid=49
priority=254 interval=1 preemption-mode=yes authentication=none password="" on-backup=""
on-master=""
R2:
priority=100 interval=1 preemption-mode=yes authentication=none password="" on-backup=""
on-master=""
I’ve tried doing a /system reset-configuration on both routers. I used to be on RouterOS 4.13, and I tried upgrading to 4.14 to see if that made a difference. Is there something I’m doing wrong, or is this a bug with RouterOS?
