VRRP-Master not Runnig Master
I hvave 2 CCR1072 that i config vrrp in both of them
when R1reboted on R2 vrrp change to Running master and after R1 came up the VRRP in R2 change to backup and in R1 VRRP change to Master not running master and not work
I have to manually disable and enable the vrrp to make it runng master
both CCR-1072 are runng v7.5
This is normal behaviour for VRRP. If node A is master and B is backup, when A fails, B becomes the master and A becomes the backup. If you wish for node A to become the master when available again, you need to enable preemption on it.
yes it is the reason for using VRRP
the problem is when nod A back online the state of VRRP in node A change to M means master but it should be RM means running master and IP on the VRRP interface is invalid
and in node B VRRP change to backup
