VRRP on VER 3
I want to make two RB600 on VRRP mode as below :
Their ether1 ports are in VLAN1 and ETHER2 ports are in VLAN2
For examlpe On the Router whom is Runing on Master Mode Ether1 IP address should be 192.168.100.1/24 and Ether 2 Should be 192.168.200.1/24.
I have two questions ,
1- I should run just one VRRP on Ether1 of both routers ? And how about IP address? Should I add on router 1 Manually and router2 by script?
2-How can I set one Router always work as Master expect fault times ? I mean when both routers are working fine , I want router 1 working as Primary
Regards
Farid Sani
CTEL Kish
