I’m trying to setup VRRP between our Microtik and a Cisco router.
VRRP is setup fine and the Microtik is the master with the Cisco as backup as planned.
The Microtik has a BGP session with our ISP and I want VRRP to decrement it’s VRRP priority if this BGP session drops so that the Cisco takes over as master. When the BGP session re-establishes I would like the VRRP priority to return to normal so that the Microtik becomes the master again.
I’m guessing this has to be done via a script but I can’t find one to do this. I’m obviously quite new to Microtik so any help much appreciated.
With Cisco/Juniper etc you can just setup a track to monitor the default route being received via BGP so hopefully there is something similar for Microtik.
Thanks!
