Hello, i plan to implement VRRP for customer redundancy but have problem with free IP's in customer subnet.
Is there way to implement this without 2 additional real/free IP's from customer subnet?
I tested following configuration:
Master: ROS 5.11, RB450G
Backup: ROS 5.11, RB750G
Master - RouterA:
[admin@RouterA] > /interface print
NAME TYPE MTU L2MTU MAX-L2MTU
0 R ether1-uplink ether 1500 1520 1520
1 R ether2-downlink ether 1500 1520 1520
2 ether3-local ether 1500 1520 1520
3 ether4-local ether 1500 1520 1520
4 ether5-local ether 1500 1520 1520
5 R vrrp1-uplink vrrp 1500
6 R vrrp2-donwlink vrrp 1500
[admin@RouterA] >
[admin@RouterA] > /interface vrrp print
Flags: X - disabled, I - invalid, R - running, M - master, B - backup
NAME INTERFACE MAC-ADDRESS VRID PRIORITY INTERVAL VERSION V3-PROTOCOL
0 RM vrrp1-uplink ether1-uplink 00:00:5E:00:01:01 1 250 1s 3 ipv4
1 RM vrrp2-donwlink ether2-downlink 00:00:5E:00:01:02 2 250 1s 3 ipv4
[admin@RouterA] /ip address> print
ADDRESS NETWORK INTERFACE
0 ;;; WAN VRRP Address
192.168.1.2/24 192.168.1.0 vrrp1-uplink
1 ;;; WAN Blind REAL
1.1.1.2/24 1.1.1.0 ether1-uplink
2 ;;; LAN VRRP
192.168.88.1/24 192.168.88.0 vrrp2-donwlink
3 ;;; WAN Blind VRRP
1.1.1.1/32 1.1.1.1 vrrp1-uplink
4 ;;; LAN Blind REAL
2.2.2.2/24 2.2.2.0 ether2-downlink
5 ;;; LAN Blind VRRP
2.2.2.1/32 2.2.2.1 vrrp2-donwlink
[admin@RouterA] /ip firewall nat> print
0 chain=srcnat action=src-nat to-addresses=192.168.1.2 src-address=192.168.88.0/24 out-interface=vrrp1-uplink
Backup - RouterB:
[admin@RouterB] > /interface print
2 ether3-slave-local ether 1500 1520 1520
3 ether4-slave-local ether 1500 1520 1520
4 ether5-slave-local ether 1500 1520 1520
5 vrrp1-uplink vrrp 1500
6 vrrp2-downlink vrrp 1500
[admin@RouterB] /interface vrrp> print
0 B vrrp1-uplink ether1-uplink 00:00:5E:00:01:01 1 100 1s 3 ipv4
1 B vrrp2-downlink ether2-downlink 00:00:5E:00:01:02 2 100 1s 3 ipv4
[admin@RouterB] /ip address> print
0 ;;; WAN Blind REAL
1.1.1.3/24 1.1.1.0 ether1-uplink
1 ;;; WAN VRRP
2 ;;; LAN VRRP
192.168.88.1/24 192.168.88.0 vrrp2-downlink
2.2.2.3/24 2.2.2.0 ether2-downlink
2.2.2.1/32 2.2.2.1 vrrp2-downlink
[admin@RouterB] /ip firewall nat> print
This seems working. So my question is, must be real ip from same subnet as virtual ip? Can someone test this? Thanks.
