VRRP with single public IP address
Colleagues, is it a supported setup to use VRRP with some dummy private IP addresses on “WAN” side and just add (single) public IP on VRRP interfaces (along side with private IP of course)?
Thank you,
Luka
At a high level, potentially yes. But you’d have use src-nat to the public IP and/or potentially other firewall nat/mangle things … but really depends on what you’re trying to do. Normally VRRP is the default gateway for a network on the LAN side, not WAN side.
