I have a topology with 2 routers (MT-CHR-1 and MT-CHR-3) that have VLAN interfaces and VRRP on top of them.
the problem is when one of the interfaces being used for VRRP connection tracking is apparently being blocked by STP and consequently VRRP interfaces on both routers are being in running&master state. The other issue is that MT-CHR-3 is unable to reach any host under 192.168.30.0/24 subnet (in the example 192.168.30.200 vlan host), so cannot reach VLAN. can anyone help me to figure out how to resolve this?
an approximate topology (excuse me for my drawing skills):
MT-CHR-3 /export:
[admin@MT-CHR-3] > /export
# 2024-09-15 11:27:45 by RouterOS 7.15.3
# software id =
/disk
set slot1 media-interface=none media-sharing=no slot=slot1
set slot2 media-interface=none media-sharing=no slot=slot2
set slot3 media-interface=none media-sharing=no slot=slot3
set slot4 media-interface=none media-sharing=no slot=slot4
set slot5 media-interface=none media-sharing=no slot=slot5
set slot6 media-interface=none media-sharing=no slot=slot6
set slot7 media-interface=none media-sharing=no slot=slot7
set slot8 media-interface=none media-sharing=no slot=slot8
set slot9 media-interface=none media-sharing=no slot=slot9
set slot10 media-interface=none media-sharing=no slot=slot10
set slot11 media-interface=none media-sharing=no slot=slot11
add name=vlan-br-1 vlan-filtering=yes
set [ find default-name=ether1 ] disable-running-check=no
set [ find default-name=ether2 ] disable-running-check=no
set [ find default-name=ether3 ] disable-running-check=no
set [ find default-name=ether4 ] disable-running-check=no
set [ find default-name=ether5 ] disable-running-check=no
set [ find default-name=ether6 ] disable-running-check=no
set [ find default-name=ether7 ] disable-running-check=no
set [ find default-name=ether8 ] disable-running-check=no
/interface vlan
add interface=vlan-br-1 name=vlan-20 vlan-id=20
add interface=vlan-br-1 name=vlan-30 vlan-id=30
/interface vrrp
add interface=vlan-20 name=vrrp-b-20 priority=190 vrid=20
add interface=vlan-30 name=vrrp-b-30 priority=190 vrid=30
add name=vlan-20-pool ranges=192.168.20.100-192.168.20.200
add name=vlan-30-pool ranges=192.168.30.100-192.168.30.200
/port
set 0 name=serial0
/routing ospf instance
add disabled=no name=ospfv2-inst router-id=1.0.0.3
/routing ospf area
add disabled=no instance=ospfv2-inst name=ospfv2-a0
add bridge=vlan-br-1 interface=ether2
add bridge=vlan-br-1 interface=ether3
add bridge=vlan-br-1 interface=ether7 pvid=30
add bridge=vlan-br-1 interface=ether8 pvid=20
/interface bridge vlan
add bridge=vlan-br-1 tagged=vlan-br-1,ether2,ether3 untagged=ether8 vlan-ids=20
add bridge=vlan-br-1 tagged=vlan-br-1,ether2,ether3 untagged=ether7 vlan-ids=30
add address=10.1.4.2/24 interface=ether2 network=10.1.4.0
add address=10.1.3.2/24 interface=ether3 network=10.1.3.0
add address=192.168.20.2/24 interface=vlan-20 network=192.168.20.0
add address=192.168.30.2/24 interface=vlan-30 network=192.168.30.0
add address=192.168.20.3 interface=vrrp-b-20 network=192.168.20.3
add address=192.168.30.3 interface=vrrp-b-30 network=192.168.30.3
add address-pool=vlan-20-pool interface=vlan-20 name=dhcp1
add address-pool=vlan-30-pool interface=vlan-30 name=dhcp2
add address=192.168.20.0/24 dns-server=192.168.20.3 gateway=192.168.20.3
add address=192.168.30.0/24 dns-server=192.168.30.3 gateway=192.168.30.3
add action=masquerade chain=srcnat out-interface=vlan-br-1
add distance=10 dst-address=0.0.0.0/0 gateway=10.1.3.1
add distance=20 dst-address=0.0.0.0/0 gateway=10.1.4.1
/routing ospf interface-template
add area=ospfv2-a0 disabled=no networks=10.1.4.0/24
add area=ospfv2-a0 disabled=no networks=10.1.3.0/24
/system console screen
set blank-interval=never line-count=40
/system identity
set name=MT-CHR-3
/system note
set show-at-login=no
MT-CHR-3 info:
[admin@MT-CHR-3] > ping 192.168.20.1
SEQ HOST SIZE TTL TIME STATUS
0 192.168.20.1 56 64 416us
1 192.168.20.1 56 64 790us
2 192.168.20.1 56 64 852us
sent=3 received=3 packet-loss=0% min-rtt=416us avg-rtt=686us max-rtt=852us
[admin@MT-CHR-3] > ping 192.168.30.1
0 192.168.30.1 timeout
1 192.168.30.1 timeout
2 192.168.30.1 timeout
3 192.168.30.2 84 64 145ms371us host unreachable
sent=4 received=0 packet-loss=100%
[admin@MT-CHR-3] > ping 192.168.30.200
0 192.168.30.200 timeout
1 192.168.30.200 timeout
sent=2 received=0 packet-loss=100%
[admin@MT-CHR-3] > /interface/vrrp/print detail
Flags: X - disabled; I - invalid; G - grp-authority, g - grp-member; R - running; M - master, B - backup, F - failure
0 B name="vrrp-b-20" mtu=1500 mac-address=00:00:5E:00:01:14 arp=enabled arp-timeout=auto interface=vlan-20 group-authority="" vrid=20
priority=190 interval=1s preemption-mode=yes authentication=none password="" on-backup="" on-master="" on-fail="" version=3
v3-protocol=ipv4 sync-connection-tracking=no
1 RM name="vrrp-b-30" mtu=1500 mac-address=00:00:5E:00:01:1E arp=enabled arp-timeout=auto interface=vlan-30 group-authority="" vrid=30
[admin@MT-CHR-3] > /interface/print detail
Flags: D - dynamic; X - disabled; I - inactive, R - running; S - slave; P - passthrough
0 name="ether1" default-name="ether1" type="ether" mtu=1500 actual-mtu=1500 mac-address=0C:F8:94:94:00:00 link-downs=0
1 RS name="ether2" default-name="ether2" type="ether" mtu=1500 actual-mtu=1500 mac-address=0C:F8:94:94:00:01
last-link-up-time=2024-09-15 06:32:48 link-downs=0
2 RS name="ether3" default-name="ether3" type="ether" mtu=1500 actual-mtu=1500 mac-address=0C:F8:94:94:00:02
3 name="ether4" default-name="ether4" type="ether" mtu=1500 actual-mtu=1500 mac-address=0C:F8:94:94:00:03 link-downs=0
4 name="ether5" default-name="ether5" type="ether" mtu=1500 actual-mtu=1500 mac-address=0C:F8:94:94:00:04
last-link-down-time=2024-09-15 09:21:58 last-link-up-time=2024-09-15 06:32:48 link-downs=1
5 name="ether6" default-name="ether6" type="ether" mtu=1500 actual-mtu=1500 mac-address=0C:F8:94:94:00:05
last-link-down-time=2024-09-15 09:21:57 last-link-up-time=2024-09-15 06:32:48 link-downs=1
6 RS name="ether7" default-name="ether7" type="ether" mtu=1500 actual-mtu=1500 mac-address=0C:F8:94:94:00:06
7 RS name="ether8" default-name="ether8" type="ether" mtu=1500 actual-mtu=1500 mac-address=0C:F8:94:94:00:07
8 R name="lo" type="loopback" mtu=65536 actual-mtu=65536 mac-address=00:00:00:00:00:00 last-link-up-time=2024-09-15 06:32:38 link-downs=0
9 R name="vlan-20" type="vlan" mtu=1500 actual-mtu=1500 l2mtu=65531 mac-address=0C:F8:94:94:00:01 last-link-up-time=2024-09-15 06:32:39
link-downs=0
10 R name="vlan-30" type="vlan" mtu=1500 actual-mtu=1500 l2mtu=65531 mac-address=0C:F8:94:94:00:01 last-link-up-time=2024-09-15 06:32:39
link-downs=0
11 R name="vlan-br-1" type="bridge" mtu=auto actual-mtu=1500 l2mtu=65535 mac-address=0C:F8:94:94:00:01 last-link-up-time=2024-09-15 06:32:39
link-downs=0
12 name="vrrp-b-20" type="vrrp" mtu=1500 actual-mtu=1500 l2mtu=65531 mac-address=00:00:5E:00:01:14 last-link-down-time=2024-09-15 06:56:04
last-link-up-time=2024-09-15 06:56:04 link-downs=5
13 R name="vrrp-b-30" type="vrrp" mtu=1500 actual-mtu=1500 l2mtu=65531 mac-address=00:00:5E:00:01:1E last-link-down-time=2024-09-15 06:56:00
last-link-up-time=2024-09-15 06:56:00 link-downs=6
[admin@MT-CHR-3] > /ip/address/print detail
0 address=10.1.4.2/24 network=10.1.4.0 interface=ether2 actual-interface=vlan-br-1
1 address=10.1.3.2/24 network=10.1.3.0 interface=ether3 actual-interface=vlan-br-1
2 address=192.168.20.2/24 network=192.168.20.0 interface=vlan-20 actual-interface=vlan-20
3 address=192.168.30.2/24 network=192.168.30.0 interface=vlan-30 actual-interface=vlan-30
4 I address=192.168.20.3/32 network=192.168.20.3 interface=vrrp-b-20 actual-interface=vrrp-b-20
5 address=192.168.30.3/32 network=192.168.30.3 interface=vrrp-b-30 actual-interface=vrrp-b-30
[admin@MT-CHR-3] > /interface/bridge/monitor vlan-br-1 once
state: enabled
current-mac-address: 0C:F8:94:94:00:01
root-bridge: no
root-bridge-id: 0x8000.0C:BF:64:AC:00:00
root-path-cost: 20000
root-port: ether8
port-count: 4
designated-port-count: 2
fast-forward: no
[admin@MT-CHR-3] > /interface/bridge/print detail
0 R name="vlan-br-1" mtu=auto actual-mtu=1500 l2mtu=65535 arp=enabled arp-timeout=auto mac-address=0C:F8:94:94:00:01 protocol-mode=rstp
fast-forward=yes igmp-snooping=no auto-mac=yes ageing-time=5m priority=0x8000 max-message-age=20s forward-delay=15s transmit-hold-count=6
vlan-filtering=yes ether-type=0x8100 pvid=1 frame-types=admit-all ingress-filtering=yes dhcp-snooping=no port-cost-mode=long mvrp=no
[admin@MT-CHR-3] > /interface/bridge/port/print detail
Flags: X - disabled, I - inactive; D - dynamic; H - hw-offload
0 interface=ether2 bridge=vlan-br-1 priority=0x80 edge=auto point-to-point=auto learn=auto horizon=none hw=yes auto-isolate=no
restricted-role=no restricted-tcn=no pvid=1 frame-types=admit-all ingress-filtering=yes unknown-unicast-flood=yes
unknown-multicast-flood=yes broadcast-flood=yes tag-stacking=no bpdu-guard=no trusted=no mvrp-registrar-state=normal
mvrp-applicant-state=normal-participant multicast-router=temporary-query fast-leave=no
1 interface=ether3 bridge=vlan-br-1 priority=0x80 edge=auto point-to-point=auto learn=auto horizon=none hw=yes auto-isolate=no
2 interface=ether7 bridge=vlan-br-1 priority=0x80 edge=auto point-to-point=auto learn=auto horizon=none hw=yes auto-isolate=no
restricted-role=no restricted-tcn=no pvid=30 frame-types=admit-all ingress-filtering=yes unknown-unicast-flood=yes
3 interface=ether8 bridge=vlan-br-1 priority=0x80 edge=auto point-to-point=auto learn=auto horizon=none hw=yes auto-isolate=no
restricted-role=no restricted-tcn=no pvid=20 frame-types=admit-all ingress-filtering=yes unknown-unicast-flood=yes
[admin@MT-CHR-3] > /interface/vlan/print detail
0 R name="vlan-20" mtu=1500 l2mtu=65531 mac-address=0C:F8:94:94:00:01 arp=enabled arp-timeout=auto loop-protect=default loop-protect-status=off
loop-protect-send-interval=5s loop-protect-disable-time=5m vlan-id=20 interface=vlan-br-1 use-service-tag=no mvrp=no
1 R name="vlan-30" mtu=1500 l2mtu=65531 mac-address=0C:F8:94:94:00:01 arp=enabled arp-timeout=auto loop-protect=default loop-protect-status=off
loop-protect-send-interval=5s loop-protect-disable-time=5m vlan-id=30 interface=vlan-br-1 use-service-tag=no mvrp=no
[admin@MT-CHR-3] > /interface/bridge/vlan/print detail
Flags: X - disabled, D - dynamic
0 bridge=vlan-br-1 vlan-ids=20 tagged=vlan-br-1,ether2,ether3 untagged=ether8 mvrp-forbidden="" current-tagged=vlan-br-1,ether2,ether3
current-untagged=ether8
1 bridge=vlan-br-1 vlan-ids=30 tagged=vlan-br-1,ether2,ether3 untagged=ether7 mvrp-forbidden="" current-tagged=vlan-br-1,ether2,ether3
current-untagged=ether7
2 D bridge=vlan-br-1 vlan-ids=1 tagged="" untagged=vlan-br-1,ether2,ether3 mvrp-forbidden="" current-tagged=""
current-untagged=vlan-br-1,ether2,ether3
MT-CHR-1 /export:
[admin@MT-CHR-1] > /export
# 2024-09-15 11:30:26 by RouterOS 7.15.3
# software id =
/disk
set slot12 media-interface=none media-sharing=no slot=slot12
/interface vlan
/interface vrrp
add interface=vlan-20 name=vrrp-m-20 priority=200 vrid=20
add interface=vlan-30 name=vrrp-m-30 priority=200 vrid=30
add address-pool=vlan-20-pool interface=vlan-20 name=vlan-20-dhcp
add address-pool=vlan-30-pool interface=vlan-30 name=vlan-30-dhcp
/port
set 0 name=serial0
add disabled=no name=ospfv2-inst router-id=1.0.0.1
/routing ospf area
add bridge=vlan-br-1 interface=ether1
add bridge=vlan-br-1 interface=ether7 pvid=20
add bridge=vlan-br-1 interface=ether8 pvid=30
add bridge=vlan-br-1 tagged=vlan-br-1,ether3,ether1 untagged=ether7 vlan-ids=20
add bridge=vlan-br-1 tagged=vlan-br-1,ether3,ether1 untagged=ether8 vlan-ids=30
add address=10.1.2.2/24 interface=ether1 network=10.1.2.0
add address=10.1.1.2/24 interface=ether3 network=10.1.1.0
add address=192.168.20.1/24 interface=vlan-20 network=192.168.20.0
add address=192.168.30.1/24 interface=vlan-30 network=192.168.30.0
add address=192.168.20.3 interface=vrrp-m-20 network=192.168.20.3
add address=192.168.30.3 interface=vrrp-m-30 network=192.168.30.3
add distance=10 dst-address=0.0.0.0/0 gateway=10.1.1.1
add distance=20 dst-address=0.0.0.0/0 gateway=10.1.2.1
add area=ospfv2-a0 disabled=no networks=10.1.2.0/24
add area=ospfv2-a0 disabled=no networks=10.1.1.0/24
/system identity
set name=MT-CHR-1
/system note
MT-CHR-1 info:
[admin@MT-CHR-1] > ping 192.168.20.2
0 192.168.20.2 56 64 897us
1 192.168.20.2 56 64 785us
2 192.168.20.2 56 64 811us
sent=3 received=3 packet-loss=0% min-rtt=785us avg-rtt=831us max-rtt=897us
[admin@MT-CHR-1] > ping 192.168.30.2
0 192.168.30.2 timeout
1 192.168.30.2 timeout
2 192.168.30.2 timeout
3 192.168.30.1 84 64 149ms793us host unreachable
[admin@MT-CHR-1] > ping 192.168.30.200
0 192.168.30.200 56 64 463us
1 192.168.30.200 56 64 799us
2 192.168.30.200 56 64 682us
sent=3 received=3 packet-loss=0% min-rtt=463us avg-rtt=648us max-rtt=799us
[admin@MT-CHR-1] > /interface/vrrp/print detail
0 RM name="vrrp-m-20" mtu=1500 mac-address=00:00:5E:00:01:14 arp=enabled arp-timeout=auto interface=vlan-20 group-authority="" vrid=20
priority=200 interval=1s preemption-mode=yes authentication=none password="" on-backup="" on-master="" on-fail="" version=3
1 RM name="vrrp-m-30" mtu=1500 mac-address=00:00:5E:00:01:1E arp=enabled arp-timeout=auto interface=vlan-30 group-authority="" vrid=30
[admin@MT-CHR-1] > /interface/print detail
0 RS name="ether1" default-name="ether1" type="ether" mtu=1500 actual-mtu=1500 mac-address=0C:BF:64:AC:00:00
1 name="ether2" default-name="ether2" type="ether" mtu=1500 actual-mtu=1500 mac-address=0C:BF:64:AC:00:01 link-downs=0
2 RS name="ether3" default-name="ether3" type="ether" mtu=1500 actual-mtu=1500 mac-address=0C:BF:64:AC:00:02
3 name="ether4" default-name="ether4" type="ether" mtu=1500 actual-mtu=1500 mac-address=0C:BF:64:AC:00:03 link-downs=0
4 name="ether5" default-name="ether5" type="ether" mtu=1500 actual-mtu=1500 mac-address=0C:BF:64:AC:00:04
5 name="ether6" default-name="ether6" type="ether" mtu=1500 actual-mtu=1500 mac-address=0C:BF:64:AC:00:05
last-link-down-time=2024-09-15 09:21:56 last-link-up-time=2024-09-15 06:32:48 link-downs=1
6 RS name="ether7" default-name="ether7" type="ether" mtu=1500 actual-mtu=1500 mac-address=0C:BF:64:AC:00:06
7 RS name="ether8" default-name="ether8" type="ether" mtu=1500 actual-mtu=1500 mac-address=0C:BF:64:AC:00:07
9 R name="vlan-20" type="vlan" mtu=1500 actual-mtu=1500 l2mtu=65531 mac-address=0C:BF:64:AC:00:00 last-link-up-time=2024-09-15 06:32:38
link-downs=0
10 R name="vlan-30" type="vlan" mtu=1500 actual-mtu=1500 l2mtu=65531 mac-address=0C:BF:64:AC:00:00 last-link-up-time=2024-09-15 06:32:39
link-downs=0
11 R name="vlan-br-1" type="bridge" mtu=auto actual-mtu=1500 l2mtu=65535 mac-address=0C:BF:64:AC:00:00 last-link-up-time=2024-09-15 06:32:38
link-downs=0
12 R name="vrrp-m-20" type="vrrp" mtu=1500 actual-mtu=1500 l2mtu=65531 mac-address=00:00:5E:00:01:14 last-link-down-time=2024-09-15 11:30:19
last-link-up-time=2024-09-15 11:30:19 link-downs=5
13 R name="vrrp-m-30" type="vrrp" mtu=1500 actual-mtu=1500 l2mtu=65531 mac-address=00:00:5E:00:01:1E last-link-down-time=2024-09-15 11:30:24
last-link-up-time=2024-09-15 11:30:24 link-downs=6
[admin@MT-CHR-1] > /ip/address/print detail
0 address=10.1.2.2/24 network=10.1.2.0 interface=ether1 actual-interface=vlan-br-1
1 address=10.1.1.2/24 network=10.1.1.0 interface=ether3 actual-interface=vlan-br-1
2 address=192.168.20.1/24 network=192.168.20.0 interface=vlan-20 actual-interface=vlan-20
3 address=192.168.30.1/24 network=192.168.30.0 interface=vlan-30 actual-interface=vlan-30
4 address=192.168.20.3/32 network=192.168.20.3 interface=vrrp-m-20 actual-interface=vrrp-m-20
5 address=192.168.30.3/32 network=192.168.30.3 interface=vrrp-m-30 actual-interface=vrrp-m-30
[admin@MT-CHR-1] > /interface/bridge/monitor vlan-br-1 once
state: enabled
current-mac-address: 0C:BF:64:AC:00:00
root-bridge: yes
root-path-cost: 0
root-port: none
port-count: 4
designated-port-count: 4
fast-forward: no
[admin@MT-CHR-1] > /interface/bridge/print detail
0 R name="vlan-br-1" mtu=auto actual-mtu=1500 l2mtu=65535 arp=enabled arp-timeout=auto mac-address=0C:BF:64:AC:00:00 protocol-mode=rstp
[admin@MT-CHR-1] > /interface/bridge/port/print detail
0 interface=ether3 bridge=vlan-br-1 priority=0x80 edge=auto point-to-point=auto learn=auto horizon=none hw=yes auto-isolate=no
1 interface=ether1 bridge=vlan-br-1 priority=0x80 edge=auto point-to-point=auto learn=auto horizon=none hw=yes auto-isolate=no
[admin@MT-CHR-1] > /interface/vlan/print detail
0 R name="vlan-20" mtu=1500 l2mtu=65531 mac-address=0C:BF:64:AC:00:00 arp=enabled arp-timeout=auto loop-protect=default loop-protect-status=off
1 R name="vlan-30" mtu=1500 l2mtu=65531 mac-address=0C:BF:64:AC:00:00 arp=enabled arp-timeout=auto loop-protect=default loop-protect-status=off
[admin@MT-CHR-1] > /interface/bridge/vlan/print detail
0 bridge=vlan-br-1 vlan-ids=20 tagged=vlan-br-1,ether3,ether1 untagged=ether7 mvrp-forbidden="" current-tagged=vlan-br-1,ether1,ether3
1 bridge=vlan-br-1 vlan-ids=30 tagged=vlan-br-1,ether3,ether1 untagged=ether8 mvrp-forbidden="" current-tagged=vlan-br-1,ether1,ether3
2 D bridge=vlan-br-1 vlan-ids=1 tagged="" untagged=vlan-br-1,ether1,ether3 mvrp-forbidden="" current-tagged=""
current-untagged=vlan-br-1,ether1,ether3
