VXLAN CRS v7.18
Hello everyone, I would like to ask a question about VXLAN in version 7.18, I’m not sure if I understood this part of the image correctly, does this mean that if I create a vxlan in a CRS 3XX SWITCH, add the VXLAN to the BRIDGE I could not pass vlan tags through it? For example vlan 20 entering tag through the sfp1 port and leaving tag through the vxlan port? In the case Using Hardware offload? would it use CPU?
Hi, according to this page L3HW Feature Support
the VXLAN functionality is very limited at the moment, if used together with L3HW offloading. Which might be enabled in your case.
