Hi Community,
I tried in my lab for the moment to use VXLAN over IPSEC between a 4011 and a Fortigate 40F.
This is the result:
- Without IPSEC, VXLAN works > I enabled a DHCP server on the Mikrotik and plug a laptop on the Fortigate and it takes an IP
- IPSEC between the 4011 and the Fortigate works
- VXLAN+IPSEC doesn’t work
About Fortinet, there are two differents configurations who are available,
-one with a VXLAN encryption in the phase 1 of IPSEC tunnel https://community.fortinet.com/t5/FortiGate/Technical-Tip-Basic-VXLAN-over-IPsec-configuration/ta-p/191207 ( I think is not compatible with Mikrotik)
- an other without the encryption https://community.fortinet.com/t5/FortiGate/Technical-Tip-VXLAN-over-IPsec-for-multiple-VLANs-using-software/ta-p/195488
I tried the both for the same result.
My first question is, someone has already use this type of configuration ? is it possible or compatible ?
If yes I will share the Mikrotik’s and Fortigate’s configuration. Maybe one of you will see my mistake
Thank you for your help
