Wake On Lan problems with RB450G under 3.30
I originally posted here: http://forum.mikrotik.com/t/newsletter-17/27984/1
but it seems like the wrong thread for it.
I’ve only been using Mikrotik for about six hours so user error is definitely a possibility.
Using an RB450G running 3.30 in a “boring NATing router” configuration with PC A and PC B plugged into ports 4 and 5, and the internet plugged into port 1.
The desirable outcome is to be able to log into the RB450, run a script and WoL either of the PCs. PC A can WoL PC B using the Linux wakeonlan script and vice versa.
If I wireshark on A, I get nothing when I try to WoL A from the RB450.
But if A tries to WoL itself, I get:
The packet is a bit ill-formed (it seems to stutter-start a couple of times), but is close enough to get the job done.
Otherwise, I have to say I’m impressed with the RB450G and Mikrotik thusfar.
it’s an IP broadcast, this is why the packet will be sent out the gateway interface. if your PC is connected elsewhere, it will not work unless you specify the output interface in the RouterOS WOL command. then it will be sent as aan ethernet broadcast, out the correct interface.
I had an inkling it was something along those lines. The docs on the wol function are just scant enough to be vague.
So, in this case, I have gateway/internet on ether1, and ether2-5 bridged. Let’s say the computer I want to wake is on ether5 at 192.168.88.10. How would I properly format the WOL command?
/tool wol 00:11:22:33:44:55 …?
see more here:
http://wiki.mikrotik.com/wiki/WOL
Still no luck:
/tool wol 00:1e:4f:c8:44:b3 interface=ether5-local
shows nothing on sniffer or wireshark. The fact that I can WoL from one PC to another on the bridge means there are no firewall problems (?)
what about interface=bridge1 ?
No change when using interface=bridge
Try to downgrade the RouterOS version and see what happens.
I don’t think that will help, WOL is a new feature, and interface selection has only recently been introduced :slight_smile: Downgrade will only get rid of WOL entirely.
We will try to repeat this setup locally.
That’s great. Let me know if you need any add’l info. I’m open to the idea that it’s just a newbie error on my part.
we found a bug and fixed it
You can’t say I didn’t tell you before!
http://forum.mikrotik.com/t/wol-what-am-i-doing-wrong/30776/1
Great. Can I test it for you?
will this be avalable in 3.31
and any ideas when this will be avalable
to use as users?
in both new versions. will be released this week
what you mean by both 3.31 and 3.32 why not just release 1 new version with all fixes in?
:open_mouth:
no, I mean v3.31 and v4
oh i get it now v4 is it v4 or still a beta?
it’s a Release Candidate (RC). look at the download page please
sorry didnt see that thanks to the mikrotik team for all the support!
cant wait for new release thanks again team keep it up
