Wake on Lan
I want to ask you if it is possible to enable wake on lan. I have one mk with nat and couple machines behind it. I wont to wake some machine from internet. I think it is not possible directly but if router could send some packet action-based (for example: incoming connection to port 1122 → sending magic packet to mac xx:xx:Xx:xx:xx)
You may find some help here:
http://en.wikipedia.org/wiki/Wake-on-LAN
Regards
Andrew
ok thanx it is working now :smiley: i have dnat to ip with static arp in router. I am using wol gui and everything works just fine
Wake-on-LAN programs
There are a number of programs available that make use of Wake-on-LAN. Among them are:
DSLReports.com - Wake Me Up - A free online java program that sends a magic packet to wake up your PC. No downloads or installation required. You must have UDP port 9 forwarded in your firewall.
Wakeonlan – a Perl script that sends magic packets.
Depicus – Free WOL tools to send a WOL packet from different programming environments, including WOL command line, WOL for Windows, WOL for ASP, WOL over the Internet, WOL Com (VB/PHP), WOL for Windows 3.1, WOL Pocket PC 2002/3, WOL for Apple Mac, WOL Monitor/Sniffer, Mac Address Arp Viewer
WOL - Magic Packet Sender – A free Windows application to store MAC addresses and send Magic Packets.
AMD PCnet Magic Packet Utility - magic_pkt.exe mpusergd.pdf
WakeUp for Mac OS X
java WOL – OS independent java WOL utility which can be launched from browser.
Wake-on-LAN Tutorial with PHP Script
WakeOnLanOverMobilephone – Wake on lan over mobile phone is a classic WakeOnLan, but you can turn on your computer over mobile phone (java application).
enterprise Wake-On-LAN – Wake on application for your organisation. Collects MAC and IP addresses, so you can wake ANY computer in your organisation.
HyperWRT - Firmware for Linksys wireless routers with WOL GUI.
Is it possible to add WOL functionality from within MikroTik RouterOS?
What would be of great importance, is to be able from within our router, which is running RouterOS e.g. v3.x,
to wake-up a remote WOL-supporting computer.
E.g. etherwake is a tool in Linux that performs exactly the above function.
Could such functionality be embedded in RouterOS?
I would like if MT create simple tool for wake up in simple click is it possible ?
