Hi.
I have a home server which is running OpenMediaVault with Docker images. As it is for my personal use and while I am not using it (80% of the day it is not used), I would like to keep it shut down.
But when I try to access it, it would turn the server on.
For example, I am running a Jellyfin server on 192.168.xxx.50:8096.
On GoogleTV, when I run the Jellyfin client, it will try to connect to the server.
Can MikroTik router intercept this connection attempt and send the packet to wake the server?
How can I achieve it?
Thank you.
