walled garden for hotspot newbie need help! :)
hi,
I am using routerOS upgraded to 2.8.18. Configured the hotspot gateway by following exactly the guide Hotspot Step by step User Guide using DHCP-pool. Everything is working fine.
Now, I want to allow non-login user with temp hotspot ip to access a https server with a fix ip.
As a test to, I tried to use yahoo as if it is my fix ip server
/ip firewall mangle add dst-address=66.94.230.37/32 mark-flow=hs-auth
Then i try to surf to yahoo without login in to hotspot. It gives me a page could not be display. Can any one tell me what did i do wrong? very new to firewall. Please guide me step by step.
First thought:
Yahoo (for example http://www.yahoo.com) has a lot more than only ONE ip address (load balancing etc.) - so you probably should try this for something easier where you definitely KNOW the ip address…
Let me further detailed by testing environment.
internet hw router 10.5.6.1
  1. mikrotik - 10.5.6.44/16
  2. webserver - 10.5.6.25/16
  3. client -WinXP
mikrotik n webserver n internet hw router on the same switch while client is peer to peer with mikrotik.
now instead of client login into hotspot i want it to be able to be able to surf to webserver 10.5.6.25/16
I did /ip mangle add dst-address=10.5.6.25/32 mark-flow=hs-auth
Testing
  1. I did https://10.5.6.25/index.php but still get page could not be displayed.
  2. I did http://www.yahoo.com , it brings me back to the login page.
  3. I login hotspot and did https://10.5.6.25/index.php and saw my index.php page.
hmm… where did i went wrong? I suspect something to do with firewall.. but what? :frowning:
Topic closed!
Please refer to the solution in topic “how to access to https server without login to hotspot”
:slight_smile:
