I am using a RB2011UAS-2HnD-IN. I would like to create two access points. the first is a walled warden which is open and only allows access to the company website, and the second is WPA secured access point for staff which has no restrictions for accessing the internet. Is this possible with my device? If so what are the rough steps needed to get there? Thanks for any help.
It’s possible.
First create 2 virtual AP interfaces with different security profiles. One you can bridge or route into the LAN. On the other one you can deploy the hotspot for wall gardening. Don’t forget to use a different subnet on the open access point with it’s own dhcp-server/ippool
