Walled Garden Issue
Hello to all,
I use Mikrotik since the beginning of last year, and whenever I find a problem I seek a solution here in the forum and it has worked so far. :slight_smile:
But today I’m caught in a spot that can not get out, and I’ll be very grateful if someone can help me.
Designed the scenery and have attached as “picture01.png” to facilitate the explanation of the problem.
Let´s do it!
Basically today I use the Mikrotik to limit access to certain sites, but my clients have certain people who may have their access and others do not. For this reason I chose to use the hotspot rb, this way I can limit access by users.
So far so good. I have two user groups where a group can access everything and the other group did not.
I found that when I use hotspot, you can not access the rb through WinBox without first logging into the hotspot.
From this question directing my research to the Walled Garden, which released the door and started WinBox access it without the need to log into hostspot.
I did this also for other services, like icmp.
And then after that brief introduction we come to my problem.
Now if i want to access the client´s RB, i just need to access the winbox and insert the client public IP.
I made a rule for remote desktop access these computers. Through a NAT to port 4444 → 3389.
So i just need to open the remote desktop connection from windows and enter the 200.200.10.17:4444. The client´s RB will handle it and make a NAT to Desktop 01 rdp port (3389)
But it just works if I log into the hotspot.
I already add the ports 4444 and 3389 at walled garden.
So I would like to use this rule like “walled garden style” where I do not need to log into the hotspot to work.
Thank you very much
