Walled Garden Rule doesnt work
i tried to add a new rule, “skydrive.live.com”, to the walled garden, but it doesn´t work.
All the other rules work normal, but if i activate this rule i get an error message “Datatransfer interrupted”.
Any ideas why it won´t work.
Rutzki
That URL redirects to a secure site (SSL). You must enter the ips of the secure site in “/ip hotspot walled-garden ip”. That site appears to use dns to load balance the servers, so I see two ips. Both must be entered there.
157.55.96.251
157.55.97.253
And that is just for the home page. Then you get redirected to a SSL server login.live.com. Those IPs are
131.253.61.80
131.253.61.84
131.253.61.86
131.253.61.96
131.253.61.98
131.253.61.100
.. and they must be entered.
And that might not be all after you login. Good luck with that.
Thx for your answer.
i tried it but nothing worked -.- To many redirects in the background.
