I’ve got a direct connection with my ISP on ETH1 with a public ip.
On eth10 i’ve got a 4G LTE router connected with 192.168.5.0/24 as “routing vlan”.
when a ping fails on eth1 i want it to switch to eth10 and when the ping is succesfull again i want it to fail back.
Now with static rutes i know you can add gateway-check but how can i do this with a dhcp client?
Also when i disable eth1 the traffic goes smoothly over eth10 but when i put eth1 back on, my pings fail. if i disable eth10 afterwards the ping works again over eth1.
And adding static routes also did not work for eth1. when i add a static route for eth10 with 0.0.0.0/0 gw=eth10 it works, but 0.0.0.0/0 gw=eth1 does not.
I just want a failover between eth1 and eth10 with eth10 as backup.
Here’s my config :
add admin-mac=74:4D:28:27:D6:03 auto-mac=no comment=defconf name=bridge
add name=bridge-vlan10
set [ find default-name=ether1 ] name=ether1-WAN01
set [ find default-name=ether10 ] name=ether10_WAN_02_BACKUP
/interface vlan
add interface=ether6 name=vlan10-eth6 vlan-id=10
add interface=ether6 name=vlan20-eth6 vlan-id=20
add interface=ether6 name=vlan30-eth6 vlan-id=30
add interface=ether6 name=vlan99-eth6 vlan-id=99
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip ipsec peer profile
add dh-group=modp2048 enc-algorithm=aes-128 name=ike1-site2
/ip ipsec proposal
add enc-algorithms=aes-128-cbc name=ike1-site2 pfs-group=modp2048
add name=pool-LAN ranges=192.168.124.10-192.168.124.254
add name=pool-wifi-guest ranges=192.168.130.10-192.168.130.250
add name=pool-wifi-office ranges=192.168.131.10-192.168.131.250
add address-pool=pool-LAN disabled=no interface=bridge-vlan10 name=dhcp-lan
add address-pool=pool-wifi-guest disabled=no interface=vlan20-eth6 name=\
dhcp-wifi-guest
add address-pool=pool-wifi-office disabled=no interface=vlan30-eth6 name=\
dhcp-wifi-office
/queue simple
add max-limit=5M/5M name=WIFI-guest-limiter target=192.168.130.0/24
add bridge=bridge comment=defconf interface=sfp-sfpplus1
add bridge=bridge-vlan10 interface=ether3
add bridge=bridge-vlan10 interface=ether4
add bridge=bridge-vlan10 interface=ether5
add bridge=bridge-vlan10 interface=ether7
add bridge=bridge-vlan10 interface=ether8
add bridge=bridge-vlan10 interface=ether9
add bridge=bridge-vlan10 interface=vlan10-eth6
add bridge=bridge-vlan10 interface=ether2
add comment=defconf interface=bridge-vlan10 list=LAN
add comment=defconf interface=ether1-WAN01 list=WAN
add interface=ether10_WAN_02_BACKUP list=WAN
/interface sstp-server server
set certificate=Server-sstp enabled=yes verify-client-certificate=yes
add address=192.168.124.1/24 interface=bridge-vlan10 network=192.168.124.0
add address=192.168.130.1/24 interface=vlan20-eth6 network=192.168.130.0
add address=192.168.132.1/24 interface=vlan99-eth6 network=192.168.132.0
add address=192.168.131.1/24 interface=vlan30-eth6 network=192.168.131.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=WAN_01 dhcp-options=hostname,clientid disabled=no interface=\
ether1-WAN01
add add-default-route=no comment=WAN_02_BACKUP dhcp-options=hostname,clientid \
/ip dhcp-server lease
add address=192.168.124.113 client-id=1:24:5e:be:23:59:35 mac-address=\
24:5E:BE:23:59:35 server=dhcp-lan
add address=192.168.124.94 client-id=1:24:5e:be:23:59:36 mac-address=\
24:5E:BE:23:59:36 server=dhcp-lan
add address=192.168.124.0/24 comment=defconf gateway=192.168.124.1
add address=192.168.130.0/24 gateway=192.168.130.1
add address=192.168.131.0/24 gateway=192.168.131.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
add action=accept chain=input comment="Lan to MGMT" dst-address=\
192.168.132.0/24 src-address=192.168.124.0/24
add action=accept chain=forward comment="WIFI kantoor to office" dst-address=\
192.168.124.0/24 src-address=192.168.131.0/24
add action=accept chain=input comment="WIFI-office to MGMT" dst-address=\
192.168.132.0/24 src-address=192.168.131.0/24
add action=accept chain=input comment="Remote MGMT" dst-address=\
192.168.132.0/24 src-address=172.16.2.0/24
add action=accept chain=input comment="SSTP TUNNEL" dst-port=443 protocol=tcp
add action=accept chain=forward comment="OVPN NAS" dst-address=192.168.124.113 \
dst-port=1194 protocol=udp
established,related,untracked
add action=drop chain=forward comment="WIFI GUEST TO LAN" out-interface-list=\
!WAN src-address=192.168.130.0/24
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
"FORWARD : SKIP fasttrack from guest network" connection-state=\
established,related src-address=192.168.130.0/24
"FORWARD : SKIP fasttrack to guest network" connection-state=\
established,related dst-address=192.168.130.0/24
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
invalid
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
out,none out-interface-list=WAN
add action=dst-nat chain=dstnat dst-port=1194 protocol=udp to-addresses=\
192.168.124.113
add distance=10 gateway=ether10_WAN_02_BACKUP
add comment="SSTP NetwerkPieter" distance=1 dst-address=172.16.2.0/24 gateway=\
10.10.10.2
/ppp secret
add local-address=10.10.10.1 name=BMSgroep remote-address=10.10.10.2 service=\
sstp
/system clock
set time-zone-name=Europe/Brussels
/system identity
set name=RB4011-Core
/system logging
add topics=sstp
/tool graphing interface
add interface=ether1-WAN01
/tool mac-server
/tool mac-server mac-winbox
