Hi everyone,
I’m trying to follow this piece of documentation about WAN failover.
High level overview:
- Masquerade is set up on the WAN interfaces
- Mangle routes are setup up on the output chain which mark new connection with a connmark depending on the output interface, and mark connections with a routing mark dependinding on the connmark
- Routes are set up to be resolved recursively, to allow for pinging an arbitrary host (this I intend to skip - I will use a custom script for link quality measurement); there’s no default route in the main routing table
Two things I find fishy:
- Except for IPsec packages, packages from the LAN interface won’t go through the output chain
- How are connections assigned to the two different WANs? The mangle rules filter on the output interface - so how is that decided in the first place since there is no default route in the main routing table?
On the second point, the output interface is of course selected by the routing process that happens before the output chain processing (after which the packet is re-routed depending on the routing mark). Thus it seems to me that, even ignoring the packet flow issue (i.e. packets don’t go through the output chain at all), this setup wouldn’t work at all as it is - it needs some way to assign packets of new connection to the right output interface during the first routing phase.
My impression is that if I were to replicate this setup, packets would simply be dropped as no matching route would be found in the main routing table (default routes are only present in the to_ISPx tables).
Am I missing something?
