xcom
March 31, 2018, 1:35am
1
My WAN IP on my Mikrotik is leaking inside my network. Is there a way to stop this?
My pfSense is reporting:
Interface: LAN
Source: Mikrotik WAN IP
Destination: voip.ms
Instead of the WAN IP it should be my internal IP that should be coming from the device up to my pfSense.
Ideas?
Thanks!
Sob
March 31, 2018, 3:03am
2
You missed a step, first you need to find out why it happens. Stopping comes after that. If it was my problem, I’d check the config, or if I couldn’t find it myself, I’d have someone else take a look.
xcom
March 31, 2018, 3:22am
3
Here is what my config looks like.
Nothings stands out to me on why is this happening…
# mar/30/2018 22:07:06 by RouterOS 6.41
# software id = AXKP-SIF0
# model = CRS125-24G-1S
# serial number =
add admin-mac= arp=proxy-arp auto-mac=no fast-forward=no \
mtu=1500 name=Bridge-pfSense protocol-mode=none
add disabled=yes fast-forward=no mtu=1500 name=bridge-trunk
set [ find default-name=ether1 ] mac-address= name=\
Port1-Mikrotik-WAN
set [ find default-name=ether2 ] mac-address= name=\
Port2-master-pfSense-Primary
set [ find default-name=ether3 ] mac-address= name=\
Port3-slave-pfSense-Secondary
set [ find default-name=ether22 ] mac-address= name=\
Port22-slave-UPLINK-Desk
set [ find default-name=ether4 ] mac-address= name=\
ether4-slave-local
set [ find default-name=ether5 ] mac-address= name=\
ether5-slave-local
set [ find default-name=ether6 ] mac-address= name=\
ether6-slave-local
set [ find default-name=ether7 ] mac-address= name=\
ether7-slave-local
set [ find default-name=ether8 ] mac-address= name=\
ether8-slave-local
set [ find default-name=ether9 ] mac-address= name=\
ether9-slave-local
set [ find default-name=ether10 ] mac-address= name=\
ether10-slave-local
set [ find default-name=ether11 ] mac-address= name=\
ether11-slave-local
set [ find default-name=ether12 ] mac-address= name=\
ether12-slave-local
set [ find default-name=ether13 ] mac-address= name=\
ether13-slave-local
set [ find default-name=ether14 ] mac-address= name=\
ether14-slave-local
set [ find default-name=ether15 ] mac-address= name=\
ether15-slave-local
set [ find default-name=ether16 ] mac-address= name=\
ether16-slave-local
set [ find default-name=ether17 ] mac-address= name=\
ether17-slave-local
set [ find default-name=ether18 ] mac-address= name=\
ether18-slave-local
set [ find default-name=ether19 ] mac-address= name=\
ether19-slave-local
set [ find default-name=ether20 ] mac-address= name=\
ether20-slave-local
set [ find default-name=ether21 ] mac-address= name=\
ether21-slave-local
set [ find default-name=ether23 ] mac-address= name=\
ether23-slave-local
set [ find default-name=ether24 ] mac-address= name=\
ether24-slave-local
set [ find default-name=sfp1 ] mac-address= name=\
sfp1-gateway
/interface vlan
add interface=Bridge-pfSense name=vlan2 vlan-id=2
add interface=Bridge-pfSense name=vlan3 vlan-id=3
add name=mactel
add name=mac-winbox
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128-cbc
add name=vlan2 ranges=10.30.10.100-10.30.10.200
add name=vlan3 ranges=10.30.20.100-10.30.20.200
add name=dhcp_pool1 ranges=10.30.2.1,10.30.2.100-10.30.2.254
add address-pool=vlan2 authoritative=after-2sec-delay disabled=no interface=\
vlan2 lease-time=3d name=server1-wireless
add address-pool=vlan3 authoritative=after-2sec-delay disabled=no interface=\
vlan3 lease-time=3d name=dmz_vlan3
add address-pool=dhcp_pool1 authoritative=after-2sec-delay interface=\
Bridge-pfSense name=dhcp1
/queue simple
add name=VoIP packet-marks=VoIP priority=2/2 target=10.30.2.0/24
add max-limit=20M/100M name="Internal Network" priority=3/3 target=\
Bridge-pfSense,Bridge-pfSense
/snmp community
set [ find default=yes ] addresses=10.30.2.13/32,10.30.2.34/32
/user group
add name=sniffer policy="ssh,read,!local,!telnet,!ftp,!reboot,!write,!policy,!\
test,!winbox,!password,!web,!sniff,!sensitive,!api,!romon,!dude,!tikapp"
add bridge=Bridge-pfSense interface=Port2-master-pfSense-Primary
add bridge=Bridge-pfSense disabled=yes hw=no interface=Port1-Mikrotik-WAN
add bridge=Bridge-pfSense hw=no interface=sfp1-gateway
add bridge=Bridge-pfSense interface=Port3-slave-pfSense-Secondary
add bridge=Bridge-pfSense interface=ether4-slave-local
add bridge=Bridge-pfSense interface=ether5-slave-local
add bridge=Bridge-pfSense interface=ether6-slave-local
add bridge=Bridge-pfSense interface=ether7-slave-local
add bridge=Bridge-pfSense interface=ether8-slave-local
add bridge=Bridge-pfSense interface=ether9-slave-local
add bridge=Bridge-pfSense interface=ether10-slave-local
add bridge=Bridge-pfSense interface=ether11-slave-local
add bridge=Bridge-pfSense interface=ether12-slave-local
add bridge=Bridge-pfSense interface=ether13-slave-local
add bridge=Bridge-pfSense interface=ether14-slave-local
add bridge=Bridge-pfSense interface=ether15-slave-local
add bridge=Bridge-pfSense interface=ether16-slave-local
add bridge=Bridge-pfSense interface=ether17-slave-local
add bridge=Bridge-pfSense interface=ether18-slave-local
add bridge=Bridge-pfSense interface=ether19-slave-local
add bridge=Bridge-pfSense interface=ether20-slave-local
add bridge=Bridge-pfSense interface=ether21-slave-local
add bridge=Bridge-pfSense interface=Port22-slave-UPLINK-Desk
add bridge=Bridge-pfSense interface=ether23-slave-local
add bridge=Bridge-pfSense interface=ether24-slave-local
set 0 dscp-based-qos-dscp-to-dscp-mapping=no
set 1 dscp-based-qos-dscp-to-dscp-mapping=no
set 2 dscp-based-qos-dscp-to-dscp-mapping=no
set 3 dscp-based-qos-dscp-to-dscp-mapping=no
set 4 dscp-based-qos-dscp-to-dscp-mapping=no
set 5 dscp-based-qos-dscp-to-dscp-mapping=no
set 6 dscp-based-qos-dscp-to-dscp-mapping=no
set 7 dscp-based-qos-dscp-to-dscp-mapping=no
set 8 dscp-based-qos-dscp-to-dscp-mapping=no
set 9 dscp-based-qos-dscp-to-dscp-mapping=no
set 10 dscp-based-qos-dscp-to-dscp-mapping=no
set 11 dscp-based-qos-dscp-to-dscp-mapping=no
set 12 dscp-based-qos-dscp-to-dscp-mapping=no
set 13 dscp-based-qos-dscp-to-dscp-mapping=no
set 14 dscp-based-qos-dscp-to-dscp-mapping=no
set 15 dscp-based-qos-dscp-to-dscp-mapping=no
set 16 dscp-based-qos-dscp-to-dscp-mapping=no
set 17 dscp-based-qos-dscp-to-dscp-mapping=no
set 18 dscp-based-qos-dscp-to-dscp-mapping=no
set 19 dscp-based-qos-dscp-to-dscp-mapping=no
set 20 dscp-based-qos-dscp-to-dscp-mapping=no
set 21 dscp-based-qos-dscp-to-dscp-mapping=no
set 22 dscp-based-qos-dscp-to-dscp-mapping=no
set 23 dscp-based-qos-dscp-to-dscp-mapping=no
set 24 dscp-based-qos-dscp-to-dscp-mapping=no
set 25 dscp-based-qos-dscp-to-dscp-mapping=no
add interface=Port2-master-pfSense-Primary list=mactel
add interface=sfp1-gateway list=mactel
add interface=Port2-master-pfSense-Primary list=mac-winbox
add interface=sfp1-gateway list=mac-winbox
/ip accounting
set enabled=yes threshold=2560
/ip accounting web-access
set accessible-via-web=yes address=10.30.2.0/24
add address=10.30.2.2/24 comment="default configuration" interface=\
Port2-master-pfSense-Primary network=10.30.2.0
add address=WANGW interface=Port1-Mikrotik-WAN network= WANIP
add address=10.30.10.1/24 interface=vlan2 network=10.30.10.0
add address=10.30.20.1/24 interface=vlan3 network=10.30.20.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid interface=\
Port1-Mikrotik-WAN
add address=10.30.2.0/24 comment="default configuration" dns-server=10.30.2.1 \
gateway=10.30.2.2 netmask=24 next-server=192.168.88.1
add address=10.30.10.0/24 dns-server=8.8.8.8 gateway=10.30.10.1
add address=10.30.20.0/24 dns-server=8.8.8.8 gateway=10.30.20.1
set allow-remote-requests=yes servers=10.30.2.1
/ip dns static
add address=10.30.2.2 name=router
/ip firewall address-list
add address=10.0.0.0/8 list=bogons
add address=172.16.0.0/26 list=bogons
add address=192.168.0.0/16 list=bogons
add action=log chain=forward dst-address-list=bogons in-interface=vlan2
add action=accept chain=forward comment="default configuration" \
connection-state=established
connection-state=related
add action=drop chain=forward comment="default configuration" \
connection-state=invalid
add action=accept chain=input connection-state=established
add action=accept chain=input connection-state=related
add action=drop chain=input in-interface=Port1-Mikrotik-WAN
/ip firewall mangle
add action=mark-packet chain=forward disabled=yes new-packet-mark=VoIP \
passthrough=yes src-address=10.30.2.53
add action=mark-packet chain=forward disabled=yes dst-address=10.30.2.53 \
new-packet-mark=VoIP passthrough=yes
add action=mark-routing chain=prerouting dst-address=!10.30.10.0/24 \
new-routing-mark=mikrotik passthrough=yes src-address=10.30.10.0/24
add action=mark-routing chain=prerouting dst-address=!10.30.0.0/16 \
new-routing-mark=pfsense passthrough=no src-address=10.30.2.175
add action=masquerade chain=srcnat comment="default configuration" \
out-interface=Port1-Mikrotik-WAN
/ip ipsec policy
set 0 dst-address=0.0.0.0/0 src-address=0.0.0.0/0
/ip proxy
set cache-path=web-proxy1
add distance=1 gateway=10.30.2.1 routing-mark=pfsense
add distance=1 gateway=WANGW routing-mark=mikrotik
/ip service
set telnet disabled=yes
set ftp disabled=yes
/lcd
set backlight-timeout=1h30m default-screen=stats
/lcd interface pages
set 0 interfaces="Port1-Mikrotik-WAN,Port2-master-pfSense-Primary,Port3-slave-\
pfSense-Secondary,ether4-slave-local,ether5-slave-local,ether6-slave-local\
,ether7-slave-local,ether8-slave-local,ether9-slave-local"
/snmp
set enabled=yes
/system clock
set time-zone-autodetect=no time-zone-name=America/Chicago
/system leds
set 0 interface=Port1-Mikrotik-WAN leds=""
/system ntp client
set enabled=yes primary-ntp=162.210.196.6 secondary-ntp=50.7.0.66
/tool e-mail
set address=10.30.2.51 from=switch@darktcp.net
/tool graphing interface
add allow-address=10.30.2.0/24
add allow-address=172.30.10.0/24
/tool graphing resource
/tool mac-server
set allowed-interface-list=mactel
/tool mac-server mac-winbox
set allowed-interface-list=mac-winbox
/tool romon port
add
mkx
March 31, 2018, 9:16am
4
Are you sure it’s Mikrotik who leaks? Any client host which has possibility of discovering public IP address (perhaps through client-server communication on Layer 7) could potentially do it.
You’ll have to trace it down using wireshark or similar tools to discover plaintiff. After you find the source, you can try to fix it.
Sob
March 31, 2018, 11:47am
5
Masquerade is only on Port1-Mikrotik-WAN, so that’s not it. In theory, if it was coming from router itself, it could decide to use WANIP as source, but it shouldn’t. Did you check what exactly it is (protocol, port)?
xcom
March 31, 2018, 1:45pm
6
It s the Mikrotik. The Protocol is SIP/UDP Port 5060
The Source is inet addr:10.30.2.175 so I know is not grabbing the WAN IP.
CZFan
March 31, 2018, 5:48pm
7
I suspect you have a NAT aware PBX system, it is a way the PBX companies are trying to workaround the NAT traversal problems, what it does (if I recall correctly) is it checks for the Public IP, and then inserts this IP into the SIP packet as the src address
xcom
March 31, 2018, 11:02pm
8
I think you are right… Not much I can do about that…
xcom
April 1, 2018, 3:51am
9
Doing some trouble shooting I found that if I block all traffic:
src: mypbx
destination: mikrotik-gateway
action: drop
The box looses all connections and can only ping internally and not out to the internet…
This tells me that the box is going out to internet via mikrotik gw and the mangle preroute rule is not working properly hence why I am seen a delay.
Thoughts?
anav
April 1, 2018, 2:52pm
10
Well make a more direct mangle rule…
all traffic from 10.30.2.5 going to Ether1 Gateway mark.
Route traffic to pfsense.
See if that more direct angle works…
CZFan
April 1, 2018, 4:45pm
11
It sounds like it is working as per design, so personally, I would not do this:
Look into your PBX config, some of them allow you to disable this functionality, but suspect you might then have many VoIP problems.
Why is it bugging you? i.e. what do you think the risks are?
xcom
April 1, 2018, 4:57pm
12
How is it working? If I am telling mikrotik that for 0.0.0.0 with a mark of pfsense to go out 10.30.2.1 which the GW is totally different…
CZFan
April 1, 2018, 6:27pm
13
How is it working? Same way as SIP ALG will work on your router / firewall / NAT device, just being done on the PBX itself instead of NAT device.
If I am telling mikrotik that for 0.0.0.0 with a mark of pfsense to go out 10.30.2.1 which the GW is totally different… If I understand you correctly, this is what I do in my environments:
All servers have static IP configs, specify the pfsense as gateway on the PBX device statically instead of wasting resources with mangle, etc on router, i.e. KISS, “Keep It Simple, S… ”
