WAN IP not reachable from LAN
my routerboard have 2 WAN IP´s both of them have a Domain like:
private.mydomain.com
from outside there is no Problem to go to the Webserver,
but from inside i will get en error.
It is possible to mak a routing mark ?
BR, Thomas
please take a look at hairpin nat
Also note there is an issue in 6.6 with this
http://wiki.mikrotik.com/wiki/Hairpin_NAT
or if you are running an internal DNS server (or DNS caching etc server on mikrotik) then you can create a static entry in the cache with the domain and pointing it at the internal IP Address of the server so it works directly.
Regards
Alexander
