Wan Monitor (Check if internet working) -UPDATED
wanmonitor.rsc: The script check if internet available via pppoe,l2tp,ether and etc… If you not set your InternetInterface(s) the script will search automatically for pppoe,l2tp,ppp,sstp and ether with dhcp client.
:if ([:len [/system scheduler find name=wanmonitor]]=0) do={
	:log warning "creating wan monitor scheduler"
	/system scheduler add name=wanmonitor interval=1h on-event="/system script run wanmonitor" start-time=startup comment="'wanmonitor' checking internet connection(s)"
} else={
	:if ([/system scheduler get value-name=on-event [/system scheduler find name=wanmonitor]]!="/system script run wanmonitor") do={
		:log warning "updating wan monitor scheduler"
		/system scheduler set on-event="/system script run wanmonitor" [/system scheduler find name=wanmonitor]
:local wmCheck do={
	#Configuration
	:local fconfig [:parse [/system script get wanmonitor.cfg source]]
	:local cfg [$fconfig]
	:local WANS ($cfg->"Interfaces")
	:local RUNONUP ($cfg->"ScriptOnUp")
	:local STORAGE ($cfg->"Storage")
	:local TGID ($cfg->"Telegram")
	#Inputs
	:local Wan [:tostr $1]
	:local Hosts [:toarray $2]
	:if ([:len $Hosts]=0) do={
		:set $Hosts "64.6.64.6,4.2.2.1"
	#Settings
	:local Runtime 0
	:local Retries 2
	#Counters
	:local Checks 0
	:local Failures 0
	#telegram command
	:local telegram
	:if ([:len [/system script find name=telegram]]>0) do={
		:set telegram [:parse [/system script get telegram source]]
	## Get gateway ip address
	:local wmGateway do={
		:if ([:len [/ip dhcp-client find where interface=$wan]]>0) do={
			:return [/ip dhcp-client get value-name=gateway [find interface=[:tostr $wan]]]
		} else={
			:return [$wan]
	## Get public ip
	:local wmAddress do={
		## Check if interface have dhcp-client return address via myip.dnsomatic.com
			:local count 0
			:local wgate [/ip dhcp-client get value-name=gateway [find interface=[:tostr $wan]]]
			/ip route add comment="tempory route for 'dnsomatic.com'..." distance=1 dst-address=[:resolve "myip.dnsomatic.com"] gateway=$wgate
			/ip route add comment="tempory route for 'dnsomatic.com'..." distance=2 dst-address=[:resolve "myip.dnsomatic.com"] type=blackhole
			:while (([:len [/file find name="wan.ip"]]=0) and ($count<10)) do={
				:delay 1s
				/tool fetch url="http://myip.dnsomatic.com/" mode=http dst-path="wan.ip"
				:set count ($count+1)
			/ip route remove [/ip route find where comment="tempory route for 'dnsomatic.com'..."]
			:if ([:len [/file find name="wan.ip"]]>0) do={
				:local results [file get "wan.ip" contents];
				/file remove [/file find name="wan.ip"]
				:return $results
		## Check if interface have ip address
		:if ([:typeof [/ip address get value-name=address [/ip address find interface=$wan]]]!="nil") do={
			:return [:pick [/ip address get value-name=address [/ip address find interface=$wan]] 0 [:find [/ip address get value-name=address [/ip address find interface=$wan]] "/"]]
		} else={
			:return "0.0.0.0"
	## Wan enable/disable
	:local wmMode do={
		:local count
		## Set firewall nat 'masquerade' enable or disable
		:if ([:len [/ip firewall nat find where out-interface=$wan and action=masquerade]]>0) do={
			if ([:tostr $mode]="enable") do={
				:local masquerade false
			} else={
				:local masquerade true
			/ip firewall nat set disabled=$masquerade [/ip firewall nat find where out-interface=$wan and action=masquerade]
		## Set add-default-route yes or no / true or false
		:if ([:pick [/interface get value-name=type $wan] ([:find [/interface get value-name=type $wan] "-"]+1) [:len [/interface get value-name=type $wan]]]="out") do={
			:local drc
				:set $drc true
			} else={
				:set $drc false
			:if (([:pick [/interface get value-name=type $wan] 0 [:find [/interface get value-name=type $wan] "-"]]="pppoe") && ([/interface pppoe-client get value-name=add-default-route $wan]!=$drc)) do={
				/interface pppoe-client set add-default-route=$drc $wan
			:if (([:pick [/interface get value-name=type $wan] 0 [:find [/interface get value-name=type $wan] "-"]]="l2tp") && ([/interface l2tp-client get value-name=add-default-route $wan]!=$drc)) do={
				/interface l2tp-client set add-default-route=$drc $wan
			:if (([:pick [/interface get value-name=type $wan] 0 [:find [/interface get value-name=type $wan] "-"]]="ppp") && ([/interface ppp-client get value-name=add-default-route $wan]!=$drc)) do={
				/interface ppp-client set add-default-route=$drc $wan
			:if (([:pick [/interface get value-name=type $wan] 0 [:find [/interface get value-name=type $wan] "-"]]="sstp") && ([/interface sstp-client get value-name=add-default-route $wan]!=$drc)) do={
				/interface sstp-client set add-default-route=$drc $wan
			:log warning ("interface $[:pick [/interface get value-name=type $wan] 0 [:find [/interface get value-name=type $wan] "-"]]-client '$wan' set 'add-default-route' to '$drc'");
		} else={
			:if ([:len [/ip dhcp-client find interface=$wan]]>0) do={
				:local drd
					:set $drd "yes"
				} else={
					:set $drd "no"
				:if ([/ip dhcp-client get value-name=add-default-route [/ip dhcp-client find interface=$wan]]!=$drd) do={
					/ip dhcp-client set add-default-route=$drd [/ip dhcp-client find interface=$wan]
					:log warning ("'$wan' dhcp-client (".[/interface get value-name=type $wan].") set 'add-default-route' to '$drd'")
	## Reset interface
	:local wmReset do={
		:local count
		:if ([/interface get value-name=type $wan]="lte") do={
			/system routerboard usb power-reset duration=1s
			:log warning "usb power ('$wan') reset..."
			:delay 3s
			:set count 0
			:while (([:len [/interface find name=$wan]]=0) and ($count<30)) do={
				:delay 1s
			:log warning "usb device ('$wan') was connected"
			:set count 0
			:while (([/interface get value-name=running [/interface find name=$wan]]=false) and ($count<30)) do={
				:delay 1s
			:log warning "interface ('$wan') is running"
			:delay 3s
				:delay 3s
				:set count 0
				:while (([/ip dhcp-client get value-name=status [/ip dhcp-client find interface=$wan]]!="bound") and ($count<30)) do={
					:delay 1s
				:log warning "dhcp-client ('$wan') bounded"
		} else={
			/interface disable $wan
			:log warning "interface '$wan' was disabled"
			:delay 500ms
			/interface enable $wan;
			:log warning "interface '$wan' was enabled"
			:delay 3s
				:set count 0
					:delay 1s
				:delay 3s
				:set count 0
					:delay 1s
				:delay 3s
	## PPP profile script
	:local onConnected do={
		## Add script to ppp profile on up ('connected')
			:local script "/interface $[:pick [/interface get value-name=type $wan] 0 [:find [/interface get value-name=type $wan] "-"]]-client monitor $wan once do={\n	:local uptime ([:tonum [:pick [:tostr \$uptime] 0 2]]*60*60+[:tonum [:pick [:tostr \$uptime] 3 5]]*60+[:tonum [:pick [:tostr \$uptime] 6 8]])\n}\n:if (\$uptime<3) do={\n	/tool netwatch remove [/tool netwatch find comment=$wan]\n	:local script [:parse [/system script get wanmonitor source]]\n	\$script wan=$wan hosts=$[:tostr $hosts]\n\n}"
			:if (([:pick [/interface get value-name=type $wan] 0 [:find [/interface get value-name=type $wan] "-"]]="pppoe") and ([:typeof [:find [/ppp profile get value-name=on-up [/interface pppoe-client get value-name=profile $wan]] "\$script wan=$wan"]]="nil")) do={
				/ppp profile set on-up=([/ppp profile get value-name=on-up [/interface pppoe-client get value-name=profile $wan]]."\n".$script) [/interface pppoe-client get value-name=profile $wan]
			:if (([:pick [/interface get value-name=type $wan] 0 [:find [/interface get value-name=type $wan] "-"]]="l2tp") and ([:typeof [:find [/ppp profile get value-name=on-up [/interface l2tp-client get value-name=profile $wan]] "\$script wan=$wan"]]="nil")) do={
				/ppp profile set on-up=([/ppp profile get value-name=on-up [/interface l2tp-client get value-name=profile $wan]]."\n".$script) [/interface l2tp-client get value-name=profile $wan]
			:if (([:pick [/interface get value-name=type $wan] 0 [:find [/interface get value-name=type $wan] "-"]]="ppp") and ([:typeof [:find [/ppp profile get value-name=on-up [/interface ppp-client get value-name=profile $wan]] "\$script wan=$wan"]]="nil")) do={
				/ppp profile set on-up=([/ppp profile get value-name=on-up [/interface ppp-client get value-name=profile $wan]]."\n".$script) [/interface ppp-client get value-name=profile $wan]
			:if (([:pick [/interface get value-name=type $wan] 0 [:find [/interface get value-name=type $wan] "-"]]="sstp") and ([:typeof [:find [/ppp profile get value-name=on-up [/interface sstp-client get value-name=profile $wan]] "\$script wan=$wan"]]="nil")) do={
				/ppp profile set on-up=([/ppp profile get value-name=on-up [/interface sstp-client get value-name=profile $wan]]."\n".$script) [/interface sstp-client get value-name=profile $wan]
		## Add script to dhcp-client on up ('bound')
		:if (([:len [/ip dhcp-client find interface=$wan]]>0) and ([:typeof [:find [/ip dhcp-client get value-name=script [/ip dhcp-client find interface=$wan]] "\$script wan=$wan"]]="nil")) do={
			/ip dhcp-client set script=("/tool netwatch remove [/tool netwatch find comment=$wan]\n:if ([/ip dhcp-client get value-name=status [/ip dhcp-client find interface=$wan]]=\"bound\") do={\n	:delay 5m\n	:local script [:parse [/system script get wanmonitor source]]\n	\$script wan=$wan hosts=$[:tostr $hosts]\n\n}") [/ip dhcp-client find interface=$wan]
	## Create netwatch
	:local addNetwatch do={
		:local ondown (":local script [:parse [/system script get wanmonitor source]]\n\$script wan=$wan hosts=".[:tostr $hosts]."\n\n");
		:if ($watch!="0.0.0.0") do={
			# Create netwatch per hosts, if not exists
			:if ([:len [/tool netwatch find where host=$watch]]=0) do={
				/tool netwatch add host=$watch down-script=$ondown comment=$wan
				/tool netwatch set down-script=("/tool netwatch remove ".[/tool netwatch find where host=$watch]."\n\n".[/tool netwatch get value-name=down-script [/tool netwatch find where host=$watch]]) [/tool netwatch find where host=$watch]
				:log info ("'$watch' netwatch has been created by script.")
			} else={
				# Set netwatch self remove, if not exists
				:if ([:typeof [:find [/tool netwatch get value-name="down-script" [/tool netwatch find host=$watch]] ("/tool netwatch remove ".[/tool netwatch find where host=$watch])]]="nil") do={
					/tool netwatch set down-script=("/tool netwatch remove ".[/tool netwatch find where host=$watch]."\n".[/tool netwatch get value-name=down-script [/tool netwatch find where host=$watch]]) comment=("internet access via '$wan' enabled from ".[/system clock get time]." ".[/system clock get date]) [/tool netwatch find where host=$watch]
				# Set append on-down event (run script), if 'wanmonitor' not exists
				:if ([:typeof [:find [/tool netwatch get value-name="down-script" [/tool netwatch find host=$watch]] "wanmonitor"]]="nil") do={
					/tool netwatch set down-script=($ondown.[/tool netwatch get value-name="down-script" [/tool netwatch find host=$watch]]) [/tool netwatch find host=$watch];
				:log info ("'$watch' netwatch has been updated by script.");
			# Set log 'error' when host is down
			:if ([:typeof [:find [/tool netwatch get value-name="down-script" [/tool netwatch find host=$watch]] ("/log error \"'$wan' was down.\"\n")]]="nil") do={
				/tool netwatch set down-script=(("/log error \"'$wan' was down.\"\n").[/tool netwatch get value-name="down-script" [/tool netwatch find host=$watch]]) [/tool netwatch find host=$watch];
	## Add scheduler
	:local AddScheduler do={
		:local schname [:tostr $1]
		:local schcode [:tostr $2]
		:local schtime [:tonum $3]
		:if ([:len $3]=0) do={
			:set $schtime 3600
		:if ([:len [/system scheduler find name=$schname]]=0) do={
			:log info ("scheduler '$schname' has been created and set to ".($schtime/60)."minutes");
			/system scheduler add interval=$schtime on-event=$schcode comment=("recheck '$schname' for internet access every ".($schtime/60)." minutes.") name=$schname
		} else={
			:if ([:typeof [:find [/system scheduler get value-name="on-event" [/system scheduler find where name=$schname]] $schcode]]="nil") do={
				/system scheduler set interval=$schtime on-event=([/system scheduler get value-name=on-event $schname].$schcode) [/system scheduler find where name=$schname]
				:log info ("scheduler '$schname' has been updated and set to ".($schtime/60)."minutes");
	## Add PPP script on up and DHCP Client script on up
	$onConnected wan=$Wan hosts=$Hosts
	## Check if interface exists, bound and enabled
	:if ((([:len [/interface find where name=$Wan]]>0) and ([/interface get value-name=running [/interface find name=$Wan]]=true) and ([/interface get value-name="disabled" $Wan]=false) and ([:len [/ip address find interface=$Wan]]>0)) and (([:len [/ip dhcp-client find interface=$Wan]]=0) or ([/ip dhcp-client get value-name=status [/ip dhcp-client find interface=$Wan]]="bound"))) do={
		## Add IP routes rules to interface
		:foreach Host in=[:toarray $Hosts] do={
			#Tempory write IP route to check specific connection
			/ip route add comment="tempory route for internet access checking..." distance=1 dst-address=$Host gateway=[$wmGateway wan=$Wan]
			/ip route add comment="tempory route for internet access checking..." distance=2 dst-address=$Host type=blackhole
		:delay 750ms;
		## Check interface's connection by ping to hosts
			:for Runtime from=1 to=$Retries do={
				:if ([/ping $Host count=1]=0) do={
					:set Failures ($Failures + 1);
					:log error "'$Wan' ping to $Host failed ($Runtime/$Retries).";
					/beep frequency=80 length=20ms
				} else={
					:log info "'$Wan' ping to $Host succeeded ($Runtime/$Retries).";
					:set $WatchIp $Host;
					/beep frequency=20 length=80ms
				:set Checks ($Checks + 1);
				:delay 500ms;
			:delay 800ms;
	} else={
		:set Failures $Checks
	## Remove IP routes rules
	/ip route remove [/ip route find where comment="tempory route for internet access checking..."]
	:if ($Failures=$Checks) do={
		:log error "internet access not available via '$Wan'!"
		$wmMode mode=disable wan=$Wan
		:if ([:len [/system scheduler find name=$Wan]]=0) do={
			$telegram action=send chat=$TGID text=("Internet access *not available* via *'$Wan'*")
			$wmReset wan=$Wan
		$AddScheduler $Wan (":local script [:parse [/system script get wanmonitor source]]\n\$script wan=$Wan hosts=".[:tostr $Hosts]."\n") 300
		:return false;
	} else={
		$wmMode mode=enable wan=$Wan
		## Check currect status and update (comment) if necessary
		if ([:len [/tool netwatch find comment=$Wan]]=0) do={
			:if ([:len [/system scheduler find name=$Wan]]>0) do={
				/system scheduler remove [/system scheduler find name=$Wan]
				:log warning "'$Wan' scheduler has been removed"
			:local publicip [$wmAddress wan=$Wan]
			$addNetwatch wan=$Wan hosts=$Hosts watch=$publicip
			:foreach script in=[:toarray $RUNONUP] do={
				:if ([:len [/system script find name=$script]]>0) do={
					:set script [:parse [/system script get $script source]]
					:if ([:find $WANS $Wan]=0) do={
						$script
					} else={
						$script interface=$Wan
			$telegram action=send chat=$TGID text=("Internet access *available* via *'$Wan'* ($publicip)")
		:return true
:if ([:len $wan]>0) do={
	:log info "Check for available internet access via '$wan' interface ...";
	if ([$wmCheck $wan $hosts]=false) do={
		## Interface's connection failed
		:log error "'$wan' failed, No internet access available.";
	} else={
		## Interface's connection check succeed
		:log info ("'$wan' succeed, Internet access available.");
} else={
	## If interfaces not set manually, searching for clients/dialup connections (pppoe, l2tp, ppp, sstp)
	if ([:len $WANS]=0) do={
		:foreach idn in=[/interface find where type="pppoe-out" and disabled=no or type="l2tp-out" and disabled=no or type="ppp-out" and disabled=no or type="sstp-out" and disabled=no] do={
			:log info ([/interface get value-name=name $idn]." detected has internet interface");
				:set $WANS ([/interface get value-name=name $idn]);
			} else={
				:set $WANS ($WANS.",".[/interface get value-name=name $idn]);
		:foreach idn in=[/ip dhcp-client find where add-default-route="yes" and status="bound" and disabled=no] do={
			:if ([/interface get value-name=type $idn]="ether") do={
					:set $WANS ([/ip dhcp-client get value-name=interface $idn]);
				} else={
					:set $WANS ($WANS.",".[/ip dhcp-client get value-name=interface $idn]);
	## Check clients (ppp/pppoe/l2tp/sstp)
	:foreach wan in=[:toarray $WANS] do={
		:set $wan [/interface get $wan name];
		:if (([:len [/interface find name=$wan]]>0) and ([/interface get value-name="disabled" $wan]=false)) do={
			:if ([:len [/tool netwatch find comment=$wan]]=0) do={
				## Check interface connection
				if ([$wmCheck $wan]=false) do={
				} else={
		} else={
			:log info ("'$wan' disabled, No internet access available.");
wanmonitor.cfg configuration script
:local config {
	"Interfaces"="pppoe-fiber,eth8";
	"Telegram"="";
	"ScriptOnUp"="ddns";
	"Storage"="disk1/";
return $config
This looks like a nice bit of code … any more info on what exactly its doing for us non scriptors ! ?
I have tried it and succeeded
I have 2 wan will it work there
