I’m not entirely sure I understand - how do the hosts on the network access the Internet if they can’t get past the WAN port on the router? Will a different router on that network serve as the Internet gateway?
That said, you can block traffic between any of the ports via IP firewall filters. A very simple approach would be the below, which assumes the WAN port is called ‘WAN’, and the four other ports are slaved together via the switch chip with a logical interface called ‘LAN’:
I sort of want it like a modem/router. I want the mikrotik to do dhcp, dns. Any Internet requests go out the WAN but no access to the network on the other side.
Yes, you can do that. It isn’t very good design since the traffic from the unsecure network behind the LAN ports of the Mikrotik has to traverse the secure network on the WAN side to get to the Internet. That is not ideal. It would be better if the two networks came off the same router - if the Mikrotik router was terminating the WAN directly, and the two LAN networks went through it. That way packets from the two LAN networks never have to touch/traverse each other.
However, you can firewall whatever you’d like. Assuming the network on the WAN side is 192.168.1.0/24, you could do this:
