Hello- new to Mikrotik devices, have seen them but not used them… so forgive my ignorance.
We have had several clients utilizing Fiber solutions - when they have a circuit with multiple IP’s the ISP basically hands them a DHCP address and then they must setup the Static Gateway and Usable IP’s behind that.
We are looking to use the Mikrotik to grab the dhcp on port 1, set a static IP address on Port 4, then connect the clients existing Firewall to port 4 (with one of the static IP’s provided by the ISP).
Do not want any firewalling - just all traffic to route in and out as smoothly as possible. If anyone can provide this new with a plan I would greatly appreciate it.
Thank you!
rplant
December 8, 2024, 11:14pm
2
The following was made on a hex, based on its default configuration.
But should be applicable to many/most Mikrotiks.
I removed all the firewall rules (so fastpath is active)
Disabled all admin services except winbox
Moved ssh and winbox access to a new vrf vrfAdmin, active on ether5.
(So you can login to the router only from ether5)
I have put a static ip (100.100.100.101/30) onto the bridge interface.
It seems to work ok, and access to the router appears to be only available from vrfAdmin (ether5).
But you would want to triple check this yourself.
I have removed all the ipv6 rules, but have disabled ipv6, and not tested it.
It seems to be able to move traffic at near 1Gbps.
If you need much more, perhaps a CRS304 with L3 hardware offload enabled would be worth trialling.
# 2024-12-08 21:09:06 by RouterOS 7.16.2
# software id = XXX-XXX
# model = RB750Gr3
# serial number = XXXXXXXXXXX
add admin-mac=XX:XX:XX:XX:XX:XX auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=ADMIN
add name=dhcp_pool1 ranges=192.168.31.20/31
add address-pool=default-dhcp disabled=yes interface=bridge name=defconf
add address-pool=dhcp_pool1 interface=ether5 lease-time=1h name=dhcp1
/ip vrf
add interfaces=ether5 name=vrfAdmin
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
/ip smb
set enabled=no
add bridge=bridge comment=defconf disabled=yes interface=ether5
set discover-interface-list=ADMIN
/ipv6 settings
set disable-ipv6=yes
add interface=ether5 list=ADMIN
add address=192.168.88.1/24 comment=defconf disabled=yes interface=bridge \
network=192.168.88.0
add address=192.168.31.1/24 interface=ether5 network=192.168.31.0
add address=100.100.100.101/30 interface=bridge network=100.100.100.100
/ip dhcp-client
/ip dhcp-server config
set store-leases-disk=2h
add address=192.168.31.0/24 dns-server=192.168.31.1
set allow-remote-requests=yes vrf=vrfAdmin
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh address=192.168.31.0/24 disabled=yes vrf=vrfAdmin
set api disabled=yes
set winbox address=192.168.31.0/24 vrf=vrfAdmin
set api-ssl disabled=yes
/system clock
set time-zone-name=Australia/Melbourne
/system identity
set name=RouteOnly
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=pool.ntp.org
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
set allowed-interface-list=ADMIN
