How can I set my WAN access to be via proxy?
Best regards
K
Best regards
K
You didn’t provide enough details (what type of proxy, where it is, what should use it). But you probably can’t anyway. If you mean connections from router itself, there’s no support for proxy as far as I know. If you mean connections from devices behind router, you can redirect them somewhere else, but it will only work with plain http, so nowadays it’s probably useless, because there’s https everywhere.
Thank you,
its a squid proxy, set in ipfire, and yes, I mean router’s access to internet should be made via proxy.
Best regards
Kostas
