this is after a lot of combinations of trying
first i tryed to make it work in local network with local ip using this and it worked but with public ip it does not work… HELP! Please it’s probably something simple that i’m missing here
(192.168.1.1 is my internal pfsense ip address and 192.168.1.213 is address given to RB on ether2-Cable)
Using WinBox
IP > Address > Add static IP from ISP and assign to the WAN Interface (probably ether1)
IP > DNS > Settings > Add DNS from ISP
This is the bit I spend a while trying to acheive…
IP > Route > Add 0.0.0.0/0 and Gateway IP from ISP
IP > DHCPClient > Dissable/Remove the DHCP client on WAN Interface (Ether1)
i googled and so on… nothing helped… When i connect my connection to pfsense with static ip it works
this probably now has errors… but i’m loosing my mind and its probably something simple…
Yes, but where are you testing from? From the computer? If so, did you set up NAT? Can you ping hosts on the Internet directly from the router, rather than through the router?
Reconnect it and try this: can you ping the default gateway from the router? Can you see it in the ARP table? Does the traffic monitor/sniffer on the router show packets leaving and entering the router?
it seams if you touch bridge on rb450g then it breaks something in config… cose i’ve done another two three factory resets.. and if i dont touch default config with bridge it works … strange
Why are you bridging things? The 450G has a built in switch chip that works in hardware at line speed if you need several ports to be on the same subnet.
