WanPMC DS3 Interface Statistics
I have a single SBE WanPMC DS3 card installed in one of my routers. Our DS3 provider is seeing CRC errors on their router. We’ve gone through a number of troubleshooting steps including swapping out cabling, etc. It would be very, very helpful to me if I were able to see CRC errors on my side as well. Does anyone know if there is a way to get more information about what’s going on with my interface?
BTW - Mikrotik: the lack of stats on this and on my ethernet interfaces makes things tough. It sure would be nice to have more there :slight_smile:
Also, just in case anyone else wants to give any advice, here’s the config for that interface:
/ interface wanpmc
set wanpmc1 name=“wanpmc1” mtu=1500 line-protocol=cisco-hdlc clock-rate=0 clock-source=external
receive-equalize=no crc32=no front-panel=yes framing-mode=hdlc frame-type=t3-cbit
fractional-mode=none fractional-bwf=0 fractional-bwl=255 long-cable=no scrambler=off
frame-relay-lmi-type=ansi frame-relay-dce=no chdlc-keepalive=10s disabled=no
