want a script to permenantly login to mikrotik radius server
hi… I was wondering if anyone could help me.
When i first connected to my mikrotik network it recognised the fact that i had to input a username and password in my browser in order to be able to use the internet.. so every time even though i never logoff it will be redirected to “HOT SPOT GATEWAY” POWERED BY MIKROTIK. i had to input a username and password in my browser in order to be able to use the internet. AFTER MY INACTIVITY FOR 10-15 MIN IT AUTOMATICALLY LOGS OFF , ITS QUITE ANNOYING… SO,I WANT TO KNOW SOMETHING ABOUT THESE
1.A SCRIPT OR PROGRAM OR ANY OTHER THAT WOULD AUTOMATICAALY INPUT MY USER NAME AND PASSWORD INTO HOT SPOT GATEWAY LOGIN PAGE AUTOMATICALLY AT SYSTEM STARTUP
2.A SCRIPT OR PROGRAM OR ANY OTHER THAT ALLOWS TO LOGIN AUTOMATICALLY (PROVIEDED TO ENTER PASSWORD AND USERNAME FOR ONLY FIRST TIME).. SOMETHING WHICH IS AUTOMATED
3. MY HOTSPOT LOGS OFF AUTOMATICALLY . SO I NEED TO GO TO LOGIN PAGE AND ENTER MANUALLY..SO AFTER LOG OFF AUTOMATICALLY.. A SCRIPT OR PROGRAM OR ANY OTHER THAT AUTOMATICALLY HELPS TO LOGIN WITHOUT MY INTERVENTION IMEDIATELY AFTER LOG OFF
do you have control/acces of the hotspot router? Or are you an end user?
i am end user sir
