Want to set up a ap client with nat
I have a RB951G-2HnD and want to set it up as an AP client to connect to a WiFi network and use NAT and have ether1 to ether5 als LAN clients.
Most is working but I have no internet access on the clients that are connected to the ether1 to ether 5 ports.
This is the config.
Wirelss is working and if I ping www.google.nl from the RB-951G-2Hnd device it is working.
On the clients connected to the mikrotik I add a static IP and DNS.
What do I miss in my config?
Bridge the right ports
/interface bridge add name=Bridge-Lan
add interface=ether1 bridge=Bridge-Lan
add interface=ether2 bridge=Bridge-Lan
add interface=ether3 bridge=Bridge-Lan
add interface=ether4 bridge=Bridge-Lan
add interface=ether5 bridge=Bridge-Lan
set wireless security profile
add name=Thuis wpa2-pre-shared-key=<> mode=dynamic-keys authentication-type=wpa2-psk
Set the wireless interface
/interface wireless
set wlan1 mode=station
set wlan1 band=2ghz-onlyn
Set wlan1 channel-width=20/40mhz-Ce
set wlan1 ssid=<>
set wlan1 security-profile=Thuis
set wlan1 disabled=no
Set DHCP Client on wlan1
/ip dhcp-client add interface=wlan1 disabled=no
Set NAT Rule
/ip firewall nat add chain=srcnat out-interface=wlan1
set IP on Bridge-Lan
/ip address add interface=Bridge-Lan address=172.16.100.1/24
Set DNS server
/ip dns set server=8.8.8.8
post also ip addresses print out.
Problem solved.
In the NAT rule there must also be: action=masquerade
Should not the WLAN also be a bridge port?? Im assuming wifi on the router unit, if its on a separate AP, attached to an etherport all is good.
