wants WDS solutions
Hi
To all Wi-Fi Support Enginer.
How to configure one MikroTik router in wds mode (at server side) with three MiKrotik Routers using same SSID.(at diffrent clients).
Means how to configure MiKroTik router in Point to Multipoint. in WDS mode using same SSID
If what you are trying to do is some sort of a mesh this is where i got the information to configure mine one…
http://wiki.mikrotik.com/wiki/Mesh_wds
It works great! One main AP set as a bridge-wds and the customer sides are at the same time a bridge to serve the customer and a wireles AP to surroundugn areas…
You will need some sort of control on the main AP, make it a hotspot so it will protect your local network…
Saludos de Mexico…
for suggesation
for mesh network it require higher level of Os .
my problume is that how to configure 4 router board in multi point mode. using wds mode having same ssid.
if you know than please replay
it sounds as you have only RouterBOARDS that are only CPE capable (as they are designed to be) you should have some AP capable hardware and then you wil lhave level 4 license that allows every configuration you could wish for.
i want to know the script that has been configured in OS.
So you are not left with no answer to your question…
Could you clarify exactly what is that you want now?
