wAP 60G experience
Hello, what are test results of this equipment?
Our experience is quite surprising, keep on mind this is WiFi Renesans..
There are very few technical information in menu. No Signal strength information, just quality and MCS modulation method. On RF spectral analyser we saw something like 2GHz channel width, but we need to get pre amplifier to see more. Estimated POut ERP is 100 mW, the gain of antenna is unknown, but we estimated something from 13-20 dBi. Anyway with this we are still linking on 200m, tests will follow! Premature Merry Christmas!!
What results are you getting?
Still expecting some kits I ordered for a test.
But in all, I expect a good result for backhauling of WiFi traffic around clusters of buildings.
A 200m LOS/nLOS distance is good enough in my use case.
200m is over the physical limit quality 30-40 points, which is almost no L2 link.. capacity is below 30mbit
Did you say below 30Mbps? At what distance do you get the full rated capacity from your test?
320m signal 80 MCS 8 full speed but one side wAP is inserted into LHG XL
Anybody know if signal level and/or MCS could be readed via SNMP? RouterOS 6.40.5
thankx, L.
More info! How exactly did you do this?
Thats not the goal at the moment, we need to find sensitivity edge level for at least MCS4 with that patch antenna, which we believe is somewhere about 140-150m, than we will move forward to concentrate signal either to horn or to waveguide.
We are now on edge of MCS0 which is BPSK, the QPSK is + 3dB, the 16QAM is + 9dB, this is overall performance windows from zero to hero..
We are now exactly 230 m far, so the 100m distance should be +6dB and more which means MCS8 = almost full speed
Other part of team is now checking up params of radio part, at least oscillator can do quite better = better sensitivity.
200m is behind the edge for using. We are expecting range of 140-160m is the max with wAP, as the gain of antenna and estimated 20dBm ERP. THis makes sense, that with antenna 1 feet you can gain next 40dB ! of gain with correct EIRP parameter, we will know more soon
It is blow. with such apperture and quality antenna you will get complete MCS12 on 1,5km
Thanks for sharing. Sure the antenna size should be small at 60GHz. And that gives the size advantage but with higher propagation losses I doubt if your signal can go far.
im already writing about this in http://forum.mikrotik.com/t/wireless-wire-rbwapg-60ad-minimum-distance/114421/1
obviously its possible to mount wap60 board inside lhg housing, i think its possible to mount in ldf housing also,
only question is how mehanical fix 60ghz antenna on top of the board before replacing housing.
further mounting ldf on a larger parabola is simple task.
dont forget big problem about aiming on 60ghz.
big question for mikrotik is why we dont have more data about 60ghz board and why we dont have more control on that boards?
there are some logic for wap60 regarding his simplified role in network.
but, how do they think we can use and setup lhg60 as PtP without detailed information about the signal,rates?
how to examine and find problem when it arises on 60ghz links if we do not have any information?
All the factors are just great. Huge propagation loss (12dB/km) are keen to dense repeating of band, the narrow beams will be ok up to 1 km. Right now we made several tweaks, making 500m with MCS 8.
Hi, totally agree there are very few user interface information fir those who use it in professional basis, but enough for dummies. I believe MikroTik will release more tweaks for this band, it is not necessary to mess with band this way. Channel width is about 2 GHz, which wastes band, and capacity on 16QAM is 4,5GBPS. This needs to be chopped to subbbands like 225MHz, 500MHz or 1GHz channels to make better location planning which will be enough to carry 500Mbit in 16QAM, or 1Gbit in 256QAM etc.. We see big underdevelopment in radio part and antenna. There are also 4 nests for modules, which will bring expansion for yx MIMO. This is complete new revolution of WISPs !
Looks like the chipsets are limited at the moment. Ignitenet (peraso chipset) does not allow to change 2GHz channelwidth, too. Esp where lower bandwidth is enough it would save spectrum. And I guess smaller channels are more stable, too. 60GHz Wifi seems to be at the beginning but will be a very valuable tool.
we cant (without enormous hassle) setup and maintain 60ghz link over more than 500m without rssi signal level.
I dont think so..they are may be limited with modulation method as the LO for multiplier is really bad parameters, but about bandwidth I am completely sure, they can do what ever they want, there is I a Q baseband with 800MHz clock ducted to balance mixer which has harmonic 8 time mulitplier, so if you will put lower baseband the lower bandwidth will be available.
If you use standard mesh antenna, which is fine for 5 GHZ you cant make fortune on 60 GHz, the wavelength is 1/2 cm, I am surprised you made more..
Only Signal and MCS are displayed (in 6.40.5). Lowest signal is 40 (MCS 4) than link disconnect. by Signal 45 is MCS 6 and by Signal 50 is MCS 8. I am not able to read both values from SNMP nor parsing web interface (to put values to my own monitoring system). Anybody have idea?
Please can you post some pics about this hack?
Thank you
