wAP 60Gx3 problem
Hello, I had a wAP 60G connection with two clients. One wAP 60G (150m) and one LHG 60G (400m) at about 50 degrees. I wanted to connect one more client out of 60 degrees. I exchanged wAP 60G for wAP 60Gx3, still with two clients. Clients have often started to disconnect since the replacement, 150 disconnections in 8 days. So I returned everything to wAP 60G. Is there any advice why wAP 60Gx3 didn’t work?
thanks, Pavel
That is Bad news, we want to Test this Sector in the Next Week in real Setup
did You try the exact same ROS version on both WAPs?
I noticed at least 3 dB less in signal reception in the WAP60x3 compared to WAP60
Yes, it’s same version od ROS
any news??
ROS version?
make sure you run the latest RouterOS version on both sides, and then send us both supout.rif files.
Email them to support @ mikrotik and we will see why it’s different on the 60Gx3
Any news?
We need to implement this solution in all our nodes to release load on the NV2 APs.
Any news about this problem?
thanks
Sorry Google translate
