Hello everyone,
I’m planning to cover a 4000 m² outdoor area (street market) with WIFI…
The idea is to deploy reliable and powerful outdoor access points to cover the street market.
These outdoor APs will be connected to the core network via fiber cables (of course there will be no SFP ports available on the APs so they’ll be connected to a local switch with SFP port which will be connected to the core network).
I would really prefer to go with Mikrotik outdoor access points since I’ve been using 100% Tik devices in my current wireless infrastructure.
After going through Mikrotik’s list of outdoor access point, I think that the best device to use in my case would be the wAP AC → https://mikrotik.com/product/RBwAPG-5HacT2HnD
First Question:
What kind of outdoor AP should I use ?
Is there a better Tik outdoor AP for my case ? and why ?
Should I consider another manufacturer ? -
Second Question:
Did anyone deploy wAP AC in similar projects ?
If yes, please share your feedback regarding performance (bandwidth, max simultaneous users etc…) -
Third Question
I know that roaming is handled on the client’s device side (95% mobile phones in my case) but some workarounds can be done to mimnimize the romaing time (kicking the client’s device off when the signal is weak, reduce the transmit power of the AP etc…)
Did anyone test these configurations in real world ? If yes, please share your feedback …
Thank you in advance.
