WAP AC interuption in WiFi connection
Hi All
I’ve a Mikrotik network with several HAP AC ap/router in my house, serviced via Capsman. So always same configurations etc
Now I have for ouside in the garden, connected a WAP AC via ùtp and PoE
I have several SSID’s, fg Basic network, guest network in 4.2 and 5 ghz. the guest network is configured as a VAP.
In house, with the HAP AC’s everything is working fine. So if you go with your phone, the phone is following the AP’s and working very well
When I go to garden, the connection is following to the WAP AC, but or the connection is lost after a short time or the transfer is stopping after a short time and the connection is not working anymore.
The solution is: disconnect the wifi at the phone and after a while make a new connection at the place of de WAP AC, or change to one of the other SSID’s
What could be the reason.
For 4.2 ghz, I use one of the not overlapping channel numbers ( 1-6-11) and also for 5 ghz a different channel nummer in the 5 ghz (AC) range
Please let me know if someone has an idea of have had a equal issue.. and how solved..
Grtz
Peter
You can start debug logging on Wifi to find out the reason. My wAP ac is not working differently form my cAP XL ac’s and cAP ac.
